Cat question... - Mustang Evolution
Old 10-08-2012, 06:34 AM   #1
daddydigest's Avatar
Cat question...
How many cats do I have to keep on my car for it to be able to still pass emissions?
daddydigest is offline   Reply With Quote
Old 10-08-2012, 07:00 AM   #2
Lorraine's driver
ab_mach1's Avatar
We have 4 stock cats. All the hi-flow cats you see on mid pipe setups have two. I'm not sure if the high flow cats pass emissions testing. Anybody ever had their car tested with them?
Instagram: @ab_mach1
Old 10-08-2012, 08:02 AM   #3
Shop wants to take the 2 cats closer to the rear and remove them. Then put in an x-pipe and relocate the o2 sensors closer to the other two stock ones. What do y'all think?
Old 10-08-2012, 08:12 AM   #4
charlie03fastGT's Avatar
In ca car won't pass smog emissions will be too high. Also with high flow cats it might not pass visual inspection and I heard emissions are still high.
charlie03fastGT is offline   Reply With Quote
Old 10-08-2012, 08:21 AM   #5
Lorraine's driver
ab_mach1's Avatar
I'm not sure if it would still pass emissions with just two stick cats.
You'll be shutting the rear O2 sensors off if you have a tuner. If you don't, you'll need two MIL eliminators. In either case, you should probably make sure the sensors aren't moved so you can leave them plugged in. The emissions tech may look under your car, so you want it to look correct.
MIL eliminators
Try to get them to keep the mid pipe dimensions correct, that way, you could replace it down the road if needed without having to mess with the rest of the exhaust. Also, this will make it easier if you decide to get a cat back setup in the future too.
Good luck!
Old 10-08-2012, 11:48 PM   #6
Region: Arkansas
For most states, as long as your O2 sensors aren't throwing codes and you don't have a custom smoke-screen exhaust system you should pass. Cut the rears and fix the sensors.
Also, MIL eliminates as stayed above.^
BackPressure is offline   Reply With Quote
09:09 PM
