FRPP INTAKE - Mustang Evolution
Old 10-08-2012, 03:13 PM   #1
Danster313's Avatar
FRPP INTAKE
Hey all
I have a 2001 GT bone stock. It was always meant to be a project and I can finally start. I need a new intake manifold and from research I've noticed everyone kinda thinks the FRPP is the way to go. Will this intake bolt on without any mods and should I replace the plenum while I'm at it? I already plan on replacing the coil packs as they are the stock ones and are failing intermittently...any help or advice would be appreciated
Danster313 is offline   Reply With Quote
Old 10-08-2012, 03:32 PM   #2
Mzilla's Avatar
Your car already has a PI intake which is the same As the FRPP intake they sell on American muscle. I would do a plenum throttle body combo with a cold air.
Mzilla is offline   Reply With Quote
Old 10-08-2012, 04:49 PM   #3
01bullitt's Avatar
get a eddie jr mani
01bullitt is offline   Reply With Quote
Old 10-08-2012, 05:24 PM   #4
infamous281's Avatar
Exhaust > Springs > Gears > Short Shifter > Plenum+70mm+Cold air intake
Old 10-08-2012, 11:39 PM   #5
Region: Arkansas
I disagree. Intakes don't really do much of anything on a stock 2v. We don't move enough air to require a bigger tb and the factory plenum/tb set is a champ already. 2v modular motors just do not respond to bolt-ons like a 4v does. Full bolt-ons run you a couple grand, but barely break the 300 mark. (ask me how I know, I dare ya )
Tuner and gears are the biggest noticeable changes. Exhaust is mostly just for aesthetics, maybe a handful of horses gained.
BackPressure is offline   Reply With Quote
Old 10-09-2012, 01:59 AM   #6
01bullitt's Avatar
i agree but disagree at same time. eddie jr or trick flow track heat or on extreme a Logan mani big tb 3inch intake 90mm maf a cam and tune you can make power till about 6300 rpm and that will be huge diffrence on a stock suck plastic intake mani with a stock air box any day.
Old 10-09-2012, 02:36 AM   #7
Coreyw428's Avatar
Region: Arkansas
I would run the tf intake if your not really planning on doing anything big to the engine, if you go with the victor jr on a stock engine your gonna lose more than you will gain
Coreyw428 is offline   Reply With Quote
Old 10-09-2012, 10:28 AM   #8
01bullitt's Avatar
the builltt/tf mani will out flow ported pi heads. the eddie and logan are for built motors and fi
Old 10-09-2012, 10:32 AM   #9
Region: Arkansas
You can run drag racing heads all day, but if you only push factory air quantities, your power gains will be minimal.
The stock GT draws somewhere between 60 and 70% (saw the numbers a while ago and may not be citing them correctly) of the factory MAF's capacity. Unless your motor is sucking liters of extra air, the stock MAF and tb are more than sufficient.
Exactly like Coreyw said, huge intakes and plenums slow the air down so much that you lose power unless you draw enough air to fill it completely.
I'm just trying to save you money on things you don't really need at the moment, not force your opinion.
Old 10-09-2012, 10:40 AM   #10
Coreyw428's Avatar
Region: Arkansas
I tried runnin a vic jr on my first setup and it didn't work out very well, first setup was a dss 5.0l stroker kit, potted and polished pi heads, and custom cams.... I literally had no bottom end power what so ever, my average 60 ft times on et street radials was a 2.35 and best time in an 8th was an 8.89
Old 10-09-2012, 10:53 AM   #11
Mzilla's Avatar
Where n/a or did you have a power adder?
Old 10-09-2012, 11:14 AM   #12
Ive seen NA GTs get 350rwhp
Non Strokers.. Non Forged Internals
---------- Post added at 12:12 PM ---------- Previous post was at 12:09 PM ----------
Your funny.. You do know 2V MAF are big enough unless you go Forced Induction.. Who has stock Quanities anyways ?
I said a 70mm That isnt big.. Stock plenum is very restricted.. stock Tb is like 52mm.. Restrictive..
If you want.more airflow get more airflow.. We are talking NA not PA
---------- Post added at 12:14 PM ---------- Previous post was at 12:12 PM ----------
A Full Bolt On GT with Tires runs 12s .. What more do you want ?
Old 10-09-2012, 11:51 AM   #13
1996mustang's Avatar
What did the na gts pushing 350hp have? Curious to know what setups they ran non fi and non stroked
Old 10-09-2012, 01:50 PM   #14
01bullitt's Avatar
a na 2v making 350. is 38cc twisted wedge heads logan intake mani notched pistons stage 5 na cam. e85 or 100 oct and a aggressive tune.
Old 10-09-2012, 04:24 PM   #15
Coreyw428's Avatar
Region: Arkansas
These runs was n/a, I was ticked about how much money I spent to barely run faster times than what it did stock so then I changed some stuff and got the twin turbo setup
Old 10-09-2012, 04:31 PM   #16
No
---------- Post added at 05:31 PM ---------- Previous post was at 05:30 PM ----------
Ported Heads
Stage 3 Cams
Full Bolt ons ( Fuel aswell, no E85 )
Dyno tuned ofcourse
Old 10-09-2012, 04:56 PM   #17
Coreyw428's Avatar
Region: Arkansas
No
Ported Heads
Stage 3 Cams
Dyno tuned ofcourse
I'll agree there, as long as the person does the research on what they get
Old 10-09-2012, 05:45 PM   #18
The person Is my Best Friend ..
Old 10-09-2012, 06:55 PM   #19
Coreyw428's Avatar
Region: Arkansas
Okay... I was agreeing that it could be done, alot of ppl don't realize there is alot of potential for a 4.6l 2 valve engine, even n/a
Old 10-10-2012, 08:31 AM   #20
truckinu's Avatar
Sorry to butt in. What does n/a mean?
Im trying to follow along on this.
truckinu is offline   Reply With Quote
Old 10-10-2012, 08:52 AM   #21
wheelman's Avatar
Naturally Aspirated
wheelman is offline   Reply With Quote
Old 10-10-2012, 09:01 AM   #22
people think they know it all
Old 10-10-2012, 10:46 AM   #23
I dont hence y i ask to gain more knowledge and help me to wake up the beast within it. Id like to know more setup na around 300 to w/e range u can get on a na w/o stroker
Old 10-10-2012, 11:39 AM   #24
Lol You dont need a stroker.. a stroker doesnt add as much power as what people may want to.believe its just setting a stable.bottom.to handle all the power you put.into.your.top end ( heads/cams/poweradder)
GTs are good to 400-450hp
Our trannys are good to 300-350tq
Old 10-10-2012, 04:50 PM   #25
Coreyw428's Avatar
Region: Arkansas
The 5.0 stroker kit is supposed to make around 40 more hp, but there are alot cheaper ways to make 40hp
Old 10-10-2012, 07:13 PM   #26
Exactly.
Old 10-10-2012, 08:54 PM   #27
Do tell, im wanting to know as much as i can b4 i start building her up
Old 10-11-2012, 12:52 AM   #28
Coreyw428's Avatar
Region: Arkansas
Everything depends on what your wanting and how deep your pockets are
04:30 AM
