Headlights pitting, can i fix this? - Mustang Evolution
Old 10-08-2012, 08:39 PM   #1
Lorraine's driver
ab_mach1's Avatar
I washed my car this evening and got finished right around dark. I noticed having the lights on and the clear lenses look like they are pitted. They are are clear and not yellowing. Do you think a headlight restore kit would remove the pitting and smooth them out?
Instagram: @ab_mach1
Old 10-08-2012, 09:40 PM   #2
1slosix's Avatar
i've tried a couple things like restore kits, toothpaste, plastix...nothing seems to fix it
carving corners like a boss
Old 10-08-2012, 09:49 PM   #3
Lorraine's driver
ab_mach1's Avatar
It sucks! You can't see that during the day. I'm a little bummed out.
Old 10-08-2012, 10:04 PM   #4
Bleem@1's Avatar
If the pitting isn't too deep you can have a detail shop buff it out with compound. I would remove the lights first though. Just so they don't burn the paint. They can also burn the lenses though😁
Bleem@1 is offline   Reply With Quote
Old 10-08-2012, 11:33 PM   #5
xhgwx's Avatar
Most of the time it's on the inside of the light btw
xhgwx is offline   Reply With Quote
Old 10-08-2012, 11:43 PM   #6
Lorraine's driver
ab_mach1's Avatar
Is that from the heat or cause they are not truly sealed? I'll feel them in the morning, but seems like I remember they felt smooth on the outside. Crazy they look okay during the day.
Old 10-09-2012, 12:10 AM   #7
DaBluedude's Avatar
Mine do this too. There really isn't a lot you can do but I you can remove some pitting with a heavy cut compound (or really gritty toothpaste *hint*) then hit it with a polishing compound then a fine polishing compound. I also did this to my windshield and pulled a lot of little scratches out. I recommend removing the headlight first.
2003 Mach 1
Old 01-12-2014, 02:28 PM   #8
jsilv468's Avatar
I put some really light feather scratches on the outside of the lens while installing the raxiom smoked ccfls halos on a 2010. Does anyone know how to take/buff those scratches out of a lens
jsilv468 is offline   Reply With Quote
Old 01-12-2014, 05:14 PM   #9
Slow4V's Avatar
Any pictures so I know what your talking about ?
I restore headlamps
Old 01-12-2014, 06:05 PM   #10
jsilv468's Avatar
I'll get them to you as soon as I get better lighting... Tomorrow morning most likely
Old 01-12-2014, 10:29 PM   #11
blacklightening's Avatar
Light compound and a careful buff job should do it.
Sent from my DROID RAZR using Mustang Evolution mobile app
blacklightening is offline   Reply With Quote
Old 01-13-2014, 11:55 AM   #12
jsilv468's Avatar
Name:	ImageUploadedByMustang Evolution1389639166.044060.jpg
It happened when I was installing the factory HID. I had the lens face down on a piece of card board and I guess there was some grit in it... They aren't very deep though
Name:	ImageUploadedByMustang Evolution1389639135.190406.jpg
Old 01-13-2014, 12:05 PM   #13
Slow4V's Avatar
Ouch, I usually sand lamps down with 4 different grits , ( low to high ) then I'll use buffing compound and my drill and buff the F out of them. And then wash off, and sand again if needed and repeat.
Old 01-13-2014, 01:57 PM   #14
jsilv468's Avatar
I think the light and just the outcome of the picture actually makes them look worse but like a I said not to deep. You can feel them with a finger but if you run a finger nail over it there is no catch like a deep scratch
Old 02-14-2014, 07:13 PM   #15
jsilv468's Avatar
What do yal think would be a fair price to sell the 2010 gt premium projector headlight housings without the hid bulb in them?
06:58 AM
