Oil pan - Mustang Evolution
Old 10-09-2012, 04:56 PM   #1
Gobabygo67's Avatar
Oil pan
Is there any way to take out the oil pan to change it without taking the transmission out or using an engine jack to jack it up and remove the pan?
Gobabygo67 is offline   Reply With Quote
Old 10-09-2012, 07:25 PM   #2
1996mustang's Avatar
Wish there was i did mine on the floor using jacks to jack ip the motor sucked on the floor lol
Old 10-13-2012, 11:13 PM   #3
CodyNelson's Avatar
Region: West Virgina
Drop the k-member
Old 10-14-2012, 01:29 PM   #4
Originally Posted by CodyNelson View Post
Drop the k-member
+1, when i did the cobra oil pan I droped the k member and placed the floor jack up under the bell housing and had no issues.
southernstang00 is offline   Reply With Quote
Old 10-15-2012, 06:00 AM   #5
Mzilla's Avatar
You know the oil pan on a GT and a Cobra are the same right. The only difference is the oil pick up and the oil pump. I called Ford and verified the part numbers.
Mzilla is offline   Reply With Quote
Old 10-15-2012, 07:34 AM   #6
Yup, sure do I just put Cobra in there because thats the only one I have done with the engine still in the car. My GT I did outside the car.
02:51 AM
