cluster swap - Mustang Evolution
Old 04-11-2008, 09:37 AM   #1
cluster swap
hi guys, bought car in us last summer, finaly tracked one in kms, instaled it and theft light is blinking and car will not start, put old one back in and car starts again, please help, its realy hard to read the small numbers on the dial, thanks
pipeguy is offline   Reply With Quote
Old 04-11-2008, 10:36 AM   #2
Herbstang's Avatar
Re: cluster swap
who's the manufactor of the unit you bought ??
Old 04-11-2008, 11:14 AM   #3
Re: cluster swap
its an original ford cluster
Old 04-11-2008, 12:38 PM   #4
Herbstang's Avatar
Re: cluster swap
Do you have a alarm system ??? what year is the mustang
Old 04-11-2008, 12:45 PM   #5
Herbstang's Avatar
Re: cluster swap
If you have a alarm this might help you out
but if it's me, on this car, I would suggest
the DIRECTED 555F bypass kit to get around the
issue for good.
This Bypass Module is designed to momentarilly
allow the engine to remote start by sending a proper
coded pulse to open the fuel rail passlock injector
cut off circuit.
The output from an alarm
would then shut down the pulse, once it has detected
the engine has engaged, and preserve the integrity
of the PATS system.
That is it's designed purpose.
However this input wire on
the 555f module, instead of going to a
momentary ground pulse from an
alarm would go to a
constant chassis ground, through
the bypass module, grounding out the PATS.
The PATS would always be bypassed as long
as that wire is chassis grounded.
this does work on bypassing
trnasponder in most all FORD vehicles
Also, this is a self learning, resistor sensing
and adjusting module. Once the PATS wires have been tapped,
you would press the program button to learn,
and it does. The car should then allow start
with any hardware store key.
Old 04-11-2008, 01:35 PM   #6
Re: cluster swap
the car is a 2000 gt convertible it helps any, thanks
Old 04-11-2008, 01:38 PM   #7
Re: cluster swap
also i have no alarm system, the car is completely stock, except for a aftermart sound system.
Old 04-11-2008, 01:48 PM   #8
Herbstang's Avatar
Re: cluster swap
Maybe it's the wiring !!!! is the dash pod you got a direct replacement for your old one ???
Old 05-08-2008, 05:52 AM   #9
Re: cluster swap
You have to replace the computer card from your old cluster to the new one
andres0286 is offline   Reply With Quote
Old 05-08-2008, 10:41 AM   #10
Send a message via AIM to rwboring
Re: cluster swap
if its the PATS then the Sniper tuning software would turn it off
rwboring is offline   Reply With Quote
Instrument cluster swap ponyboy94 Pre-2005 V6 Mustang 17 09-28-2010 06:09 AM
Cluster Scobra Pre-2005 V6 Mustang 4 04-15-2010 02:46 PM
instrument cluster swap pipeguy General Mustang Discussion 0 04-11-2008 09:43 AM
V8 cluster? fasternu_674 Pre-2005 V6 Mustang 4 11-27-2007 06:56 AM
Need a new cluster.. V6Polish Pre-2005 V6 Mustang 5 07-09-2007 12:13 PM
09:58 PM
