One legger burnouts - Traction-Lok clutches? - Mustang Evolution
Old 10-10-2012, 04:30 PM   #1
Sonicblue11's Avatar
I have been noticed when I burnout my passenger side tire only spins, I think it may be time for a rebuilt right?
Sonicblue11 is offline   Reply With Quote
Old 10-10-2012, 04:33 PM   #2
wc3john's Avatar
Are you coming to a stop then doing it?
Try this
For instance at the track ( or street ), back up about 7 or 8 feet for good measure then do it. Both tires should now spin. Common problem I've found with the t-lok
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-10-2012, 05:17 PM   #3
Try this
Yeah I have been doing it at a complete stop, should i got to reverse then right to first and do it?
Old 10-10-2012, 05:28 PM   #4
wc3john's Avatar
Yeah I go to a complete stop then roll in reverse about 7-8 feet like said and do it then. Spin both tires no problem... I get a weird look from other guys at stoplights sometimes though lol
Old 10-10-2012, 06:49 PM   #5
infamous281's Avatar
Lol your not a honda.. I used to only burn one tire.. only because One tire was better than the other .
get new tires or record your burnout so I can see if both tires are spinning
Old 10-10-2012, 06:51 PM   #6
wc3john's Avatar
And how many miles do you have on your rear-end? Some T-Loks don't do it, but then again, they don't have 150000 miles on them either... Like mine
Old 10-10-2012, 06:53 PM   #7
Mine has 171k On my rear end ( Besides my 373 Gears ) and I still burnout and go slide ways like a champ
Old 10-10-2012, 07:39 PM   #8
I have 103k on this motor and I can go sideways like a champ too but idk man today was weird with it, I getting 3.73 gears soon along with a rebuild
Old 10-10-2012, 07:45 PM   #9
wc3john's Avatar
Did you rebuild yours when you had the gears put in?
Old 10-10-2012, 11:50 PM   #10
waybad's Avatar
I have the same problem, I was told to add some "friction modifier" to my rear end, or do a rebuild. Scared me a bit getting a little sideways at the strip!
waybad is offline   Reply With Quote
Old 10-11-2012, 12:32 PM   #11
Mathew r Wright's Avatar
Mine one legs it some times I noticed that tires and certain pavement makes a difference
---------- Post added at 01:32 PM ---------- Previous post was at 01:30 PM ----------
I like to rap that sucker up in the rpm's then let loose that makes a difference...
Mathew r Wright is offline   Reply With Quote
Old 10-12-2012, 12:21 PM   #12
TXstang125's Avatar
Road surface dose matter at the strip I put it in 1st roll forward a little hit the brake and gas and I get them both spinning with that rear end getting a little side ways , on the streets I can only one to spend most of the time it depends on the road type
TXstang125 is offline   Reply With Quote
10:37 AM
