Water in Engine?! - Mustang Evolution
Old 10-10-2012, 10:34 PM   #1
TopgearGT's Avatar
Water in Engine?!
Not to long ago i took my stang to the ford dealer to replace the uim and had them replace spark plugs while they were at it. After I got the car back it started bogging down especially when i was giving it more gas. I notice it happens more when the AC is on and there have also been a few occasions of water pooling up under the car after it sits for a while. When the AC isn't running the sputter is less frequent. The other day I washed the car and sprayed down the engine to get some of the dust and grime off it. When driving it home after washing it the sputtering was really bad and the car was really bogging down. Could this be water in the engine or possibly water dripping down onto the exhaust manifolds? I you read all this then THANK YOU! please help!
p.s. I told all this to the ford dealer and they refuse to belive it has anything to do with water! going in for another check up on saturday!
http://www.mustangevolution.com/forum/users/25023-albums2837-17413.jpg
CSVT and 02 GT!
TopgearGT is offline   Reply With Quote
Old 10-10-2012, 10:39 PM   #2
Voltage258's Avatar
Region: Utah
Does not really sound like water in the engine its self. Could be water in a harness or something somewhere but I would kind of doubt that too... The water pooling up is probably just condensation off the ac. It could be a ton of different things. And the reason it does it more with the ac on, is because the ac puts more of a load on the engine. And what the fuh is a uim?
If your getting good gas mileage, your not having fun.
Voltage258 is offline   Reply With Quote
Old 10-10-2012, 10:43 PM   #3
Silver Pony's Avatar
Sounds like maybe a cracked intake manifold.
Silver Pony is offline   Reply With Quote
Old 10-11-2012, 08:04 AM   #4
wereKEV's Avatar
wtf is a uim?
wereKEV is offline   Reply With Quote
Old 10-11-2012, 08:10 AM   #5
Snapple750's Avatar
UnInsured Motorist?
User identity module?
Upper intake manifold?
2 Legit 2 Quit
Snapple750 is offline   Reply With Quote
Old 10-11-2012, 04:35 PM   #6
1996mustang's Avatar
Could be a freeze plug.
Old 10-11-2012, 04:49 PM   #7
Do u mean the upper manifold,,if so they may not have seal it right or maybe cracked..If you have coil over plugs,,you could have water down in the spark plug holes,, if you wash the engine,,if so you have to remove the coils to blow out the water ,,Listen for a possible intake leak or vacuum leak,,that could cause that problem too
mymustang is offline   Reply With Quote
Old 10-12-2012, 09:32 AM   #8
TopgearGT's Avatar
Upper intake manifold and it looks like that's the issue. I just has it replaced and the three bolts on the left side by the water crossover pype are very loose. I'm gonna have the Ford dealership tighten em up!
CSVT and 02 GT!
Old 10-15-2012, 09:51 AM   #9
New me's Avatar
What was it
New me is offline   Reply With Quote
Old 10-15-2012, 03:53 PM   #10
TopgearGT's Avatar
It was actually nothing involving water, air, or the intake manifold. It was actually a part of the alternator going bad sending out a frequency that threw off the cam positioning sensor. This created a miss fire in the engine because the cams were confused on where they were supposed to be. Never even crossed the dark corners of my mind but when they unpluged the alternator it stopped and the code went away!
CSVT and 02 GT!
Old 10-15-2012, 04:19 PM   #11
maldog's Avatar
Region: Nevada
Glad u got it fixed.....damn UIM lol
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 10-16-2012, 08:09 AM   #12
TopgearGT's Avatar
haha yep
CSVT and 02 GT!
Old 10-16-2012, 08:51 AM   #13
Lorraine's driver
ab_mach1's Avatar
Dang, read through everything. Glad you are back to running good.
Instagram: @ab_mach1
10:30 AM
