Inflating my tires for my stang. - Mustang Evolution
Old 10-11-2012, 03:10 PM   #1
lynnshowoff's Avatar
at the gas station now.. 2004 mustang gt 275 front tires, 315 back tires.. Anyone know the proper air pressure to fill my tires?!?!
lynnshowoff is offline   Reply With Quote
Old 10-11-2012, 03:15 PM   #2
usually 35ish. but the tires usually say on them.
Old 10-11-2012, 03:18 PM   #3
Thank you!! Much appreciated!
Old 10-11-2012, 03:19 PM   #4
your welcome.
Old 10-11-2012, 06:54 PM   #5
M97cobra's Avatar
I run at 32psi got svt 17's with 275's 35psi can be a little to hard sometimes depending on type of tire if your middle of your tire starts to ware faster back down your pressure a couple pounds
M97cobra is offline   Reply With Quote
Old 10-11-2012, 08:25 PM   #6
I have the same set up and run 35 psi.
WICKED STANG 83 is offline   Reply With Quote
Old 10-11-2012, 09:48 PM   #7
UltArc's Avatar
2012 v6 with 2013 OEM 18" GT rims and P Zeros. I run 56 psi.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 10-12-2012, 04:29 AM   #8
jdavis96gt's Avatar
Region: West Virgina
Sticker in my glovebox says 245/40/17 is 32
275/40/17 is 30 pds
Old 10-12-2012, 04:38 AM   #9
It all boils down to what the tire is rated for and how hard it is. A higher psi will help with gas mileage. But a lower psi will make a smoother ride.
Old 10-12-2012, 04:48 AM   #10
Dub9stang's Avatar
56 psi?!? Damn that's a little high. And don't go off of what it says on the sidewall, that's usually max psi. If you can't find the tires specific recommendation go off of the door placard (VIN sticker)
Dub9stang is offline   Reply With Quote
Old 10-12-2012, 07:32 AM   #11
I would run 32-34psi front and back. keep an eye on the wear in the middle, make sure its even if it wears on the sides then needs air vs middle that has to much air.
Old 10-12-2012, 07:49 AM   #12
UltArc's Avatar
40% over max psi. On brand new tires, it works. Allegedly tires are capable of handling 2,3,400 times their max. I would never suggest that to anyone, please do not try it, but talking to people online about tires, new production tires are extremely strong.
I wouldn't go past 150% max, ESPECIALLY if they are not new.
Old 10-12-2012, 07:56 AM   #13
Run 32-34 that will work great, and keep the car aligned good. Rotate regularly unless staggered then inflation and alignment is even more important lol
Old 10-12-2012, 08:01 AM   #14
UltArc's Avatar
I would suggest what another person mentioned, going off of the sidewall. I know my stock v6 17s had a different max than the stock 18s. Your car sticker, I believe, is made for Yeh stock tires. Whatever you do, you are better off being safer than sorry. At the end of the day, cracks, dry rot, and damaged tires cannot take a higher psi or as much of a beating.
Old 10-18-2012, 01:32 PM   #15
I agree 100%!!!
---------- Post added at 01:32 PM ---------- Previous post was at 01:29 PM ----------
I agree with dub9stang
01:30 AM
