removed guage needles,now are wrong - Mustang Evolution
Old 04-13-2008, 12:26 AM   #1
hey guys, did a cluster swap keeping original circuit board, for some dumb a## reason i pulled the needles of now they dont match what they were, i had quarter tank now i have 3 quarters, temp shows me half, but the car is cold and the speedogoes up when you turn key and stops at 20 miles and rpm same fashion, all help is apeciated, thanks
pipeguy is offline   Reply With Quote
Old 04-13-2008, 09:01 AM   #2
Region: Oregon
Re: removed guage needles,now are wrong
Personally I would just pull the needles off and put them back where they should be, two spoons can help in getting under the needles and popping them off. Tach is pretty easy to do, speedo can be done with a friend and a GPS on a straight road, temp I do by driving around and waiting for the engine to get up to temp, for fuel I drive the car to a gas station and fill it up simple as that.
Kendellgil is offline   Reply With Quote
Old 04-13-2008, 10:53 AM   #3
fill up the car with gas and put the needle on the full mark like it normally is when the car is 100% full. Let the car warm up 100% and put the temp needle in the middle (or where it normally is under normal operating temps)
for the oil pressure have the car turned on and put it in the middle.
for the battery do the same as the oil pressure
for the speedo get someone to drive by you if pre 99 and stick it on at the right mph, check it at 45-55-65 for accuracy. If 99 up turn the key to on but dont crank hold down the trip button for a few seconds until the gauges flip (or the odometer screen changes cant remember which) and then crank the car and push the odometer button to flip through the options to speedo and rpm and set them while driving.
for the rpm if you dont have this you will have to get a calculator for your car and set rpm at XX mph and check it at like 45-55-65-xx mph to make sure its accurate.
Old 04-14-2008, 04:03 PM   #4
thanks guys i did the button thing its a 2000gt, worked like a charm.
gauge needles jwhitaker45 1996-2004 Mustang GT 5 05-10-2010 07:24 AM
Gauge needles mchaggis50 General Mustang Discussion 6 08-11-2009 01:23 PM
11 Cousins Have Their Stomachs Removed Brent The Bar 2 06-18-2006 11:20 PM
Removed my A/C Ibanezplayer272 Pictures and Videos 6 02-02-2006 10:12 AM
Crazy Vid, wrong place wrong time Black95GT The Bar 19 06-26-2004 03:38 PM
03:07 PM
