how much $ - Mustang Evolution
Old 10-15-2012, 01:43 PM   #1
shsfresh87's Avatar
Region: West Virgina
how much $
How much money would i be into if i wanted to drop a 4.6L DOHC 4v crate engine into my 01 GT? What would the modifications be to put it in? I don't know much about engine swaps so any advice would be most helpful, thanks
shsfresh87 is offline   Reply With Quote
Old 10-15-2012, 02:27 PM   #2
frank07stanggt's Avatar
You will also need a new ECM and wiring harness for that motor. You might want to check on the transmission too. Idk if they will bolt right up or if you need anything for it. Also the heads are gigantic on the 4v and I don't know how everything is positioned in a 2v as far as air conditioning and fuse boxes and other misc stuff like that. You may need to reposition some things to make room. Good luck.
frank07stanggt is offline   Reply With Quote
Old 10-15-2012, 02:38 PM   #3
Matticus's Avatar
Subscribing, this has been on my agenda as well. And I thing the T-45 should fit the 4v, but I may need confirmation on that.
Matticus is offline   Reply With Quote
Old 10-15-2012, 02:57 PM   #4
Mile high JDF's Avatar
32VNomad has a 2V to 4V swap thread in the stickies. That should answer a lot of your questions
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
09:34 PM
