Compression reading? - Mustang Evolution
Old 10-15-2012, 05:43 PM   #1
Mathew r Wright's Avatar
Ey guys just a quick question. When doin a compression test on a 99-04 gt, what pressure reading should be on each cylinder???
Mathew r Wright is offline   Reply With Quote
Old 10-15-2012, 07:33 PM   #2
Does 170-180 sound good to you guys?
Old 10-15-2012, 08:36 PM   #3
1996mustang's Avatar
Yea im sure ots good
Old 10-15-2012, 09:10 PM   #4
Cool I was hoping so thanks...
Old 10-16-2012, 12:33 PM   #5
cliffyk's Avatar
The lower service limit is 135 psi; it is also important that the lowest cylinder be no less than 75% of the highest reading...
Old 10-16-2012, 06:01 PM   #6
Well I'm good then
12:00 PM
