Alternator - Mustang Evolution
Old 10-16-2012, 07:47 AM   #1
chris25's Avatar
Alternator
I have steeda underdrive pulleys on my Mustang and my alternator went out what do I need to take off the pulley off the alternator
chris25 is offline   Reply With Quote
Old 10-16-2012, 07:59 AM   #2
Las0mbra's Avatar
The alternator you buy to replace it should say the minimum and the maximum speeds it can be spun. They should provide formulas for you and instructions. After you check that you can use the steeds pulley on it, then I would worry about how to get it off the old one.
Old 10-16-2012, 08:05 AM   #3
chris25's Avatar
Ok but do i need a special tool to take It off
Old 10-16-2012, 08:07 AM   #4
Lorraine's driver
ab_mach1's Avatar
Doesn't the Alt pulley bolt on?
Instagram: @ab_mach1
Old 10-16-2012, 08:17 AM   #5
chris25's Avatar
Im not sure I had a shop do It
Old 10-16-2012, 11:12 AM   #6
infamous281's Avatar
Unscrew the bolt.holding.it.Lol
hammer.it off if its stuck
Old 10-16-2012, 11:31 AM   #7
cliffyk's Avatar
Impact wrench to get it off, impact wrench and 75 lb-ft torque stick to put it back on...
HF has a nice set of torque sticks on sale for for $70 now, and often on sale for less. I've had a set for years...
Old 10-16-2012, 05:27 PM   #8
LAS97GT's Avatar
Seriously! Steeda is one of the manufacturers that own original Ford factory specs for most early stangs. The spin ratio is already included. The UDPs come with a pulley for the alternator. I have a Steeda kit. No worries , just swap. Do a search on my handle and find out. Thanks.
---Las97GT
Old 10-16-2012, 05:41 PM   #9
LAS97GT's Avatar
Ford alternators use a locking washer to hold the pulley. Just unscrew it! No issues. Wear gloves, grab the pulley, easy with an air wrench.
---------- Post added at 07:39 PM ---------- Previous post was at 07:38 PM ----------
No hammers allowed in the engine area!!!!
---------- Post added at 07:40 PM ---------- Previous post was at 07:39 PM ----------
Good and tight will do.
---------- Post added at 07:41 PM ---------- Previous post was at 07:40 PM ----------
Hand tight.
---Las97GT
03:24 AM
