camshaft - Mustang Evolution
Old 10-16-2012, 08:40 AM   #1
takero5623's Avatar
camshaft
Hey guys i need to know which cam would be good for my 98 gt
takero5623 is offline   Reply With Quote
Old 10-16-2012, 08:46 AM   #2
wc3john's Avatar
Pi head swap or trick flow heads and cams
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-16-2012, 08:49 AM   #3
takero5623's Avatar
Ok and how much would all of that cost installed
Old 10-16-2012, 08:50 AM   #4
wc3john's Avatar
Trick flow will probably cost you about 700 more than the pi swap. And installation varies. But trick flow will be a bit more aggressive and pick up probably an extra 20-30 hp.
Old 10-16-2012, 08:52 AM   #5
takero5623's Avatar
Ok but what cam do i get
Old 10-16-2012, 08:53 AM   #6
wc3john's Avatar
Well with the pi swap I'd just stick with the pi cams. If you get the trick flow then just get the trick flow cams. It also depends on what mods, kind of driving, is it a dd... Etc. the more info you can give the better
Old 10-16-2012, 08:58 AM   #7
takero5623's Avatar
Shiet the car is basically stock all it has is the intake and the exhaust lol thats how it came when i bought it but im just starting on the car so i really need to know what upgrades to start off with without messing up the engine or transmission
Old 10-16-2012, 09:00 AM   #8
wc3john's Avatar
One more thing... What's your budget?
Old 10-16-2012, 09:05 AM   #9
takero5623's Avatar
Low
Old 10-16-2012, 09:06 AM   #10
wc3john's Avatar
Pi swap then
Old 10-16-2012, 09:08 AM   #11
takero5623's Avatar
What else would give me good hp and acceleration
Old 10-16-2012, 09:11 AM   #12
Butch's Avatar
Region: New Mexico
Gears/ acceleration
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 10-16-2012, 09:13 AM   #13
wc3john's Avatar
Gears would be the best bang for the buck
Old 10-16-2012, 09:17 AM   #14
takero5623's Avatar
I know the gears are like 180 but how much would it be to install it
Old 10-16-2012, 09:18 AM   #15
wc3john's Avatar
Varies. I've had a dealership tell me 800 once and i promptly gave them the bird. I wouldn't pay any more than 450 personally
Old 10-16-2012, 09:19 AM   #16
Butch's Avatar
Region: New Mexico
About 4-6k. Ja jk just depends on the shops in your area
-----NEHP---
{Never Enough HP}
Old 10-16-2012, 09:19 AM   #17
Lorraine's driver
ab_mach1's Avatar
I agree, gears. Instant satisfaction right there
Instagram: @ab_mach1
Old 10-16-2012, 09:20 AM   #18
takero5623's Avatar
**** ill do it my self then i would think that they would go on just how u took the other ones out am i right???
Old 10-16-2012, 09:23 AM   #19
wc3john's Avatar
No lol. There's ALOT to it and if it goes wrong, best case you ruin spider gears and worst case you lose control and it comes out from underneath you
---------- Post added at 10:23 AM ---------- Previous post was at 10:22 AM ----------
You got to pay to play! Going fast aint cheap!
Old 10-16-2012, 09:24 AM   #20
Lorraine's driver
ab_mach1's Avatar
Your much better off having a shop do it. You need experience to do that job properly. Do it wrong and you'll need another set in a few weeks.
Old 10-16-2012, 09:28 AM   #21
takero5623's Avatar
Haha damn well faaaaackkkk
---------- Post added at 10:28 AM ---------- Previous post was at 10:26 AM ----------
Yeah yall right i just dont want to get screwed on the prices
Old 10-16-2012, 09:31 AM   #22
wc3john's Avatar
Like butch said previously, prices should be in the 400 to 600 range. Just find a mechanic you trust that won't skip steps, etc.
Old 10-16-2012, 09:35 AM   #23
takero5623's Avatar
Yeah thanks for the info
Old 10-16-2012, 01:22 PM   #24
taylor98gt's Avatar
Pi heads and intake with mild porting and stage 2 comp cams, with a good tune will give you around 80hp roughly. The pi swap alone is good for about 30-40 to the wheels, it raises compression on our 96-98 gt's to like 10.5/1ish. But like they said just do gears and a tuned combo, that way your speedo ain't off, and you don't rack up miles quicker. As for install get a dealer ship would be best, because you have to get the backlashing set perfectly or it'll wine and eat your ring and pinion gear up fasttt.
taylor98gt is offline   Reply With Quote
Old 10-16-2012, 05:06 PM   #25
takero5623's Avatar
Thanks
Old 10-16-2012, 05:22 PM   #26
LAS97GT's Avatar
Hi, just completed a head swap an more last month(SEP). Please do a search on LAS97GT. I swapped non- to ford racing PIs. 10:1 comp, and 44.9 CI. Not much different than trick flows if you ask me. Most pros will steer you away from trick flows since you will have a hard time upgrading to forced induction. I chose stock heads. I can burn rubber whenever I want, and more. Check it out!
---------- Post added at 07:22 PM ---------- Previous post was at 07:21 PM ----------
---Las97GT
11:57 AM
