2005 8.8 - Mustang Evolution
Old 10-16-2012, 10:14 PM   #1
Send a message via Yahoo to Flex
2005 8.8
Hey dudes‚
Does anyone know if an 8.8 from a 2005 can be used in a 2000. I know the driveshaft flange is different.
Flex is offline   Reply With Quote
Old 10-16-2012, 10:19 PM   #2
1996mustang's Avatar
Interesting question....ill stay tuned to also find out
Old 10-16-2012, 11:14 PM   #3
The file photo shows some differences. Perhaps the spring mounts are on the axle and it appears that there may be mounts for a panhard bar. If the control arms mount in the same locations and the axle is the same width or slightyly wider, then it may just be a matter of changing out the driveshaft flange.
05:20 PM
