No turn signals but have hazard lights. - Mustang Evolution
Old 10-18-2012, 08:28 AM   #1
I have a 01 gt and the turn signals just stopped working. Neither the back or front ones are working and on the gage cluster it's not working either. The hazard lights come on both front and back. Any ideas??
M_Wag is offline   Reply With Quote
Old 10-18-2012, 09:49 AM   #2
Silver Pony's Avatar
Have you checked your fuses?
Silver Pony is offline   Reply With Quote
Old 10-18-2012, 10:10 AM   #3
1996mustang's Avatar
I would replace the flasher cheap to get and easy to install. But yeah like he said check fuses but im pretty sure its either ur flasher or could be the turn signal switch....worst case scenario of course
Old 10-18-2012, 10:23 AM   #4
Na I haven't checked the fuse. Do u know what number is the fuse? And what is the flasher? And I know on my blazer I had to replace the entire turn signal switch and it wasn't cheap. I'm hoping its not that.
Old 10-18-2012, 01:06 PM   #5
JetLife 01GT's Avatar
Fuses are under the steering wheel. Here's a diagram. Sorry I don't have a better pic. You'll have to zoom in. I'd check 13 and 18
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
11:48 AM
