H&R Springs - Mustang Evolution
Old 10-18-2012, 01:49 PM   #1
JetLife 01GT's Avatar
H&R Springs
Just got in my H&R Super Sport springs. I'm gonna put them on soon with bike tubes no iso's. Am I going to need CC plates or can I get away with just camber bolts? I've read conflicting views on whether or not I'm gonna need CC plates. Anyone with these springs, what did you use? Here's a link to springs. http://www.americanmuscle.com/h-r-sp...ngs-96-04.html
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 10-18-2012, 02:00 PM   #2
ive never used camber bolts so I dont know but something will be required regardless. Some CC plates wont give you enough adjustment also so research that. I would aim for MM's 4 bolt CC plates.
Old 10-18-2012, 02:07 PM   #3
Okay I'll check those out
2001 GT
Old 10-18-2012, 04:01 PM   #4
98vertgt's Avatar
I have the 4 bolt mm cc plates with h&r's and my alignment shop was able to get it perfectly back into spec
98vertgt is offline   Reply With Quote
Old 10-18-2012, 04:01 PM   #5
Sonicblue11's Avatar
That's funny haha I got mine like 3 weeks ago and I'm using the stock isos, why bike tube?
Sonicblue11 is offline   Reply With Quote
Old 10-18-2012, 04:53 PM   #6
RUNNWLD's Avatar
Region: Utah
I did mine with stock isos to get more of a drop but still have isos and I used camber bolts and got a perfect alignment so the bolts will work!!!! Happy lowering!!
RUNNWLD is offline   Reply With Quote
Old 10-18-2012, 09:25 PM   #7
Because they're thinner and will give it more of a drop. And bike tubes are more durable then things like duct tape or electrical tape. Or nothing lol. I don't want squeaks.
---------- Post added at 08:25 PM ---------- Previous post was at 08:24 PM ----------
Thanks man! Appreciate the info
2001 GT
Old 10-18-2012, 09:48 PM   #8
How long did it take you to do the springs?
Old 10-18-2012, 10:03 PM   #9
RUNNWLD's Avatar
Region: Utah
About 4 hours the back was just a pain cause i had some bolts that were a pain and the *** to get out!!
Old 10-19-2012, 04:30 AM   #10
It might take me alittle longer with the shocks and struts haha
Old 10-19-2012, 06:14 AM   #11
RUNNWLD's Avatar
Region: Utah
Haha yeah probably!!
Old 10-19-2012, 06:51 PM   #12
Where did you put the jack stands under? The subframe connectors?
Old 10-19-2012, 07:47 PM   #13
LAS97GT's Avatar
CC PLATES help If your front wheels are over sized. I had to use them. Stock broke apart
---Las97GT
Old 10-19-2012, 07:50 PM   #14
RUNNWLD's Avatar
Region: Utah
Yes!!
Old 10-19-2012, 11:10 PM   #15
Yes!!
Okay haha
Old 10-19-2012, 11:16 PM   #16
RUNNWLD's Avatar
Region: Utah
Post pics when done!!
Old 10-20-2012, 10:30 PM   #17
I got everything on today! It looks good and I will have pics tmmrw for before and after, but man 4 hours my *** haha it took like 7 hours man, we got the front struts with the springs on with no problem but my tie rod end was completely torn so I had to replace that, after that it was a breeze but them another problem came up, fml right?! Lol the bolts where the rear and the lower control arm connects to we're all boogered up and didn't want to budge for anything, had to run to Home Depot to get new bolts for that but to get the bolt out was a pain! It literally took like 3 hours just to get them out on both sides of the rear but I guess hard work pays off right? :p but the ride is great and better than ever! Going through tight corners is great, no more body roll or flew its just stiff all around and feels great! So happy with H&R super sport and tokico shocks and struts= a great combo! Every mustang should have them!!
Old 10-20-2012, 10:44 PM   #18
truckinu's Avatar
Do you know if you need CC plates or anything yet?
truckinu is offline   Reply With Quote
Old 10-20-2012, 10:52 PM   #19
Not yett haha it doesn't feel like it does but I will later down the line
Old 10-20-2012, 11:17 PM   #20
RUNNWLD's Avatar
Region: Utah
I told you man gives it a badass stance right!!!
---------- Post added at 11:17 PM ---------- Previous post was at 11:17 PM ----------
You used stock isos right?
Old 10-20-2012, 11:37 PM   #21
Yeah it does man! And yeah I used the stock ones they were perfectly fine haha how long did it take for yours to settle?
Old 10-21-2012, 12:42 AM   #22
I have h&r springs on mine. They dropped it about 1.75 inches. It has a good stance and a good tight feel to it. I ordered some cam bolts hopefully that's all I need for an alignment.
Cdbformula is offline   Reply With Quote
Old 10-21-2012, 01:13 AM   #23
RUNNWLD's Avatar
Region: Utah
About 2 weeks to fully settle my car was settle a lot from just driving so much it was already lower than some cars at stock height when I was stock it lowered it about 1.6in so probably 2 in if I was at regular stock hight.
---------- Post added at 01:13 AM ---------- Previous post was at 01:12 AM ----------
That's all you'll need that's what I have and they did a perfect alignment!!
12:15 AM
