2001 Cobra Project - Mustang Evolution
Old 10-18-2012, 06:10 PM   #1
bmabbott's Avatar
2001 Cobra Project
Hey guys and gals!
Tomorrow night I am beginning tear-down on my 2001 cobra. Car runs great, but I have bad valve stem seals.... giving me an excuse to convince my wife to let me spend money on a full rebuild.... YES!
I am going to be installing the following.
-Heads are being ported and polished (~stage 2) by a local shop
-new valve seals
-Ford GT Supercar cams
-high performance springs
-Billet cam spacer
-new lifters
-90mm Lightning MAF
-36# injectors
-Tubular K member
-Longtubes and o/r H pipe
-Full-tilt-boogie (5000) bushing kit
Then a Dyno tune to top it off...
Car has a brand new short block, with a terminator crank, as of January 2012... but the guy before me re-installed the heads with bad valve seals...
Does anyone have any suggestions or GOOD advice?
This is going to be my first build with a OHC setup... so it's pretty new to me, but I'm having help from my Father-in-law who has some knowledge of these heads... so we'll be fine as long as we take our time.
I'm going to keep the car N/A for now... so don't tell me to add a blower...
Thanks!
ID:	72695   Click image for larger version
*01 Cobra, 4.6L, P&P heads, Stage 3 comp cams, MAC LT headers, O/R Hpipe, Bassani catback exhaust, Too many bolt-ons to list..., 4.30 gears. (364 rwhp/ 330 rwtq)
*01 Roush Stage 2, 4.6L, 5 spd, BBK Bolt-ons (Wife's)
*71 Chevelle, 350, 4 spd, H/C/I, (~400 hp)
*72 C10, 350, Auto, (my Daily Driver)
bmabbott is offline   Reply With Quote
Old 10-19-2012, 01:58 PM   #2
bmabbott's Avatar
Really? There aren't any Do-it-yourselfers in the Mustang world?
Old 10-19-2012, 02:12 PM   #3
Lorraine's driver
ab_mach1's Avatar
Could be because its in the SVT section. I'll move the thread to the 96 - 04 section and see if she gets some lookers.
Instagram: @ab_mach1
Old 10-19-2012, 03:45 PM   #4
infamous281's Avatar
Goodluck , Ive done a rebuilt in my GT just make sure to torque things down to specs and get new mounts.
Old 10-19-2012, 04:59 PM   #5
poncho2049's Avatar
are you going to have the local shop install all the valvetrain or are you going to do it? if they arent i would see how much they charge to assemble. I only say that because it is so tedious and irritating installing the springs. i always found it better to just pay someone to do it haha
poncho2049 is offline   Reply With Quote
Old 10-19-2012, 07:30 PM   #6
LAS97GT's Avatar
Aww, SVT, no problem. Wondering though, why 36 lb injectors? Also, are u upgrading the fuel system?
---Las97GT
Old 10-21-2012, 02:22 PM   #7
bmabbott's Avatar
I'm doing all the work myself. Just wanting advice for installing timing chain with 4 cams... so GT guys with only 2 cams can't really answer this question. That's why I posted to the SVT section...
---------- Post added at 02:19 PM ---------- Previous post was at 02:15 PM ----------
Because my 24# injectors are maxed out with just bolt-ons and a racing tune... so I will definitely need new injectors after full heads/cams/exhaust work. 24# injectors are only suppose to be good for about 320-340 bhp... that's the factory horsepower for this car... May be getting a pair of factory terminator injectors, that will do the trick. Fuel system won't need replaced unless I throw boost on it... You can always tune bigger injectors to act smaller... but not the other way around.
---------- Post added at 02:22 PM ---------- Previous post was at 02:19 PM ----------
The guy who is porting my heads is also installing the lifters, springs, and valve seals... all included in his price that he quoted me, so I'm definitely gonna let him do it... Thanks!
Old 10-23-2012, 07:01 PM   #8
bmabbott's Avatar
Would anyone happen to know if there is any real performance gain from having valve work done with larger valves put in? The guy that's going to work on my heads was asking if I had ordered any larger valves or if I just wanted him to clean up my stock valves... Thanks!
Old 10-24-2012, 07:43 AM   #9
WheelStander's Avatar
Nice ride!
WheelStander is offline   Reply With Quote
Old 10-24-2012, 08:25 AM   #10
wc3john's Avatar
Larger valves, more flow into the actual clylinder... So yes it's worth it
I chug syrup for money...
wc3john is offline   Reply With Quote
Old 10-24-2012, 09:34 AM   #11
Butch's Avatar
Region: New Mexico
Ad a blower!!!! Ja jk, sweet plan you got there sir.
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 10-25-2012, 09:54 AM   #12
Nate98stang's Avatar
Originally Posted by bmabbott
Hey guys and gals!
-new valve seals
-Billet cam spacer
-new lifters
-90mm Lightning MAF
-36# injectors
-Tubular K member
Thanks!
Sexy car
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 10-25-2012, 06:38 PM   #13
bmabbott's Avatar
I did some research and called MMR (since I'm ordering most of my parts from them anyways)
Going with .5 mm-Over valves... the tech at MMR said you can't go wrong with that. Not a huge performance gain, but will give me a higher quality valve and open the door for more power adders later. More research showed that any larger than that can lead to the valves being too heavy, causing them not to open and close properly...
Just a little FYI
Old 11-11-2012, 03:54 PM   #14
bmabbott's Avatar
Finally got the heads off. Kind of a pain to get them off, but went fairly smoothly. Discovered that my vlaves weren't closing completely, AND that the previous owner re-installed a bad head gasket on the passenger side when he installed the heads on the new shortblock...
Now, I'm going with the Comp Cams 106500 instead of the supercar cams because the supercar cams are on a 4 month waiting list... and their not worth waiting that long...
ID:	75617   Click image for larger version
ID:	75619   Click image for larger version
Old 11-11-2012, 04:03 PM   #15
bmabbott's Avatar
Also.. I know Underdrive Pulleys seem like something that's OK to go with the cheaper brand to save some $... but a word of warning, I was leaking some oil at the from of my motor, and when I pulled the crank pulley off, it had a large groove in it. Just a poor quality pulley that wore out. So just a heads up before any of you go buying the SR Performance pulley. I'm going to get Steeda now so this doesn't happen again.
Old 11-12-2012, 09:14 AM   #16
Nice rides bro.
What's that Chevelle got?
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
Old 11-13-2012, 06:03 PM   #17
bmabbott's Avatar
Originally Posted by WheelStander
Nice rides bro.
My signature pretty much explains what both cars have... But the chevelle is getting a new cam and heads this winter too... But it's not really ever gonna be a speed demon...
Old 11-13-2012, 06:47 PM   #18
Harper's Avatar
I'd say that list looks pretty good on parts, however the single most important thing i would make sure it absolutely right is the heads, make sure you put enuff spring pressure but not over the top, something durable...a good valve job from a reputible company.
just having your valves close all the way, and that head gasket is going to make a huge difference on power.
did you do a compression test on each cylinder before tearing it down?
Remember to MATCH all of the components from the tb, intake, heads, valves, springs, cams, every component, headers, x or h pipe, mufflers, and even the size of the tail pipe, gear ratio, and depending on what you are wanting this car to do...tires...
if you build a HUGE amount of power and have crappy tires on there (especially with 4:10 gears) your wasteing ur money imho.
good luck. sweet looking ride.
2003 COBRA/2004 GT w DOHC Cobra Engine and trans/5spd. IN PROGRESS
67 Mustang Coupe.
1965 F100 w/EFI 5.0 w 5spd.
Harper is offline   Reply With Quote
Old 11-13-2012, 07:15 PM   #19
bmabbott's Avatar
Already ahead of you...
It's a brand new short block... Heads are being machined/assembled by a professional. I already have every bolt-on you can do... Nitto 555R's... Just need to to the ftbr5000 bushing kit, and get a good dyno tune... (Looks like Kurgan may do it)... And this thing should be pretty nasty for a N/A Cobra.
Old 11-13-2012, 07:17 PM   #20
Harper's Avatar
sounds good.
throw up a dyno jpg when you get it done. I always like to see those
67 Mustang Coupe.
Old 11-13-2012, 07:34 PM   #21
bmabbott's Avatar
sounds good.
Will do. I will keep updating this thread throughout the rebuild...
Old 11-13-2012, 09:45 PM   #22
32vNomad's Avatar
Originally Posted by bmabbott View Post
I'm doing all the work myself. Just wanting advice for installing timing chain with 4 cams... so GT guys with only 2 cams can't really answer this question. That's why I posted to the SVT section...[COLOR="Silver"]
This is the file you need. Any questions I can help. Did my engine 99% (machining done by a shop) Heads ported by me.
32vNomad is offline   Reply With Quote
Old 11-14-2012, 08:08 AM   #23
Harper's Avatar
saved...thanks 32vnomad...
67 Mustang Coupe.
Old 11-19-2012, 04:15 AM   #24
bmabbott's Avatar
OK.
Going with the Comp Cams stage 2 (106400) instead of the supercar cams...
Just trying to figure out who will give me the best deal on them... looks like MMR at the moment. Hoping to order tomorrow.
Is RPMOutlet still in business? the website is up, but isn't functioning when you try to buy something... and no one answered the phone when I called... cause their prices are the cheapest.
Old 11-19-2012, 05:39 AM   #25
I thnk they might be under a diff website now or something and are reselling mostly hids or something like that.
I would stick with Mmr or risk losing your money IMO.
Old 11-25-2012, 05:04 PM   #26
bmabbott's Avatar
Measured my bore... just to make sure that everything's good...
Discovered this block is bored .060 over. Brand new sleeves and oversized pistons. Makes this motor a 289. (4.735 Liters)
Would have been nice to know that before...
Old 11-25-2012, 06:00 PM   #27
32vNomad's Avatar
Um just a question did you take the heads off with the cams still installed????
Old 11-25-2012, 06:12 PM   #28
bmabbott's Avatar
Yes. had the intoned at TDC, and had A tool to hold them in place to make sure my mechanic can mark where they were...
---------- Post added at 08:10 PM ---------- Previous post was at 08:09 PM ----------
Engine*** not intoned, lol
---------- Post added at 08:12 PM ---------- Previous post was at 08:10 PM ----------
I also marked all the timing chains... I did it all "by the book"... Everything is good so far.
Old 11-25-2012, 08:43 PM   #29
32vNomad's Avatar
Just so you know when you remove the crank bolt, you are to reinstall it with a dab of silicone. This is in the removal and install instruction from Ford.
Old 03-15-2013, 05:12 PM   #30
bmabbott's Avatar
Also need a new bolt since It's TTY. We just dropped the motor in, and am hoping to fire it up by tomorrow. Dyno tune coming soon. I'll post a video and pic of the dyno sheet.
Old 03-15-2013, 05:18 PM   #31
bmabbott's Avatar
Stage 3 comp cams in ported heads. Comp Cam adjustable cam gears, Mmr lightweight cam spacers, Manley performance springs, new valves, new lifters, new valve guides
centerforce duel friction clutch
Mac LT headers, A/C delete pulley, Steeda UD pullies
Old 05-01-2013, 03:54 PM   #32
bmabbott's Avatar
If anyone is still folowing this post....
Here were the numbers from after the dyno tune:
384 rwhp
372 rwtq
Now, this was on a Mustang Dyno, which I believe read lower than a dyno jet. On May 18th, I will have a DynoJET number.
I still feel this is a pretty good number for a N/A motor with stock compression! It equals about 450 bhp assuming a 15% drivetrain loss.
Old 05-01-2013, 04:13 PM   #33
384 rwhp
372 rwtq
Not bad!
Old 05-01-2013, 04:34 PM   #34
MidnightBlueGT's Avatar
384 rwhp
372 rwtq
Sick n/a build. Ready to sell? lol
Old 05-01-2013, 08:31 PM   #35
Count Dragula's Avatar
You gotta do a video!!!!
2007 Mustang Gt
2.3L Whipple Supercharger
3.73 Gears
XXR 521 Wheels
20x8.5 and 20x10.5
03:50 PM
