My situatuion - Mustang Evolution
Old 10-21-2012, 10:07 AM   #1
Mustang_Madness's Avatar
My situatuion
my v8 isnt performing nearly as well as it should. Its pushing out Maybe 40-50% of what it could Really do. My cousin drove it for a while and he broke it because now theres a huge whistle/whine coming from the back of the engine and a bunch of hot air to. Just in the back. What should i do? Take out the engine and rebuild it up? Or swap engines and rebuild. I know i want forged internals because my goal is 400+ hp so however i can get it there.. Thatd be great. thanks for the comments..
K&N CAI, Cobra 18" Rims, Cobra Brakes, More Mods to come!
Mustang_Madness is offline   Reply With Quote
Old 10-21-2012, 10:17 AM   #2
mcvicar04's Avatar
Depends on cash flow is the car your dd do you need it on the road now or can you wait? Because you can get 4.6 motors out of crown Vic's and f-150 for under 500$ that run fine, and a rebuilt will be around 1,000 minimum. It all depends on you
mcvicar04 is offline   Reply With Quote
Old 10-21-2012, 10:23 AM   #3
Im in the AirForce and can pretty much walk to work for the next few years. I got friends who can drive me around if need be. Why would a rebuild be so much? Just for the parts to swap into it?
Old 10-21-2012, 10:33 AM   #4
mcvicar04's Avatar
Because you have to hone the block all new gaskets and rebuild heads and if you want new pistons and stuff it's a lot more
Old 10-21-2012, 11:24 AM   #5
So would it be better to buy an engine off of other ford 4.6s and put it in and thats it? I could take mine out and rebuild it, meanwhile have it running at least with another engine in it..
Old 10-21-2012, 03:09 PM   #6
Coreyw428's Avatar
Region: Arkansas
WhAt year is your car?
Coreyw428 is offline   Reply With Quote
Old 10-21-2012, 08:21 PM   #7
I have a 96 that had a v6 in it but a guy before me swapped it out for a 98 V8
Old 10-21-2012, 11:39 PM   #8
infamous281's Avatar
If your in the airforce trash that car and get a better one later.. Sounds like a money pit
Old 10-21-2012, 11:59 PM   #9
Butch's Avatar
Region: New Mexico
Make your friend pay for what ever needs fixing or have em put that money into the next step. Id say go forged, more money now but just think new motor 500 + 1000 more later on for forged, just throwing numbers out, go forged either way that seems to be your goal. At least IMO id go forged, :like a boss:
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 10-22-2012, 12:55 AM   #10
Coreyw428's Avatar
Region: Arkansas
Easiest thing to do and the 1st I'd do is a get a pi engine, or get the heads and build that block
Old 10-22-2012, 11:37 AM   #11
I dont want to just trash the car! Ive already put alot of money and time into it and everything! Is it better to just buy a pi engine off a trashed 99-04 or buy new heads and do that all on mine..?
ID:	73160   Click image for larger version
Old 10-22-2012, 11:45 AM   #12
jdavis96gt's Avatar
Region: West Virgina
Pi heads on 96-98 is more HP than pi engine. But you have to run better gas for the higher compression ratio.
Old 10-22-2012, 11:48 AM   #13
So i should park it, drain everything out, disassemble it all, and swap heads an all. Would it make sense to go forged at that point? Its lookin to be a year long project which is fine for me.
Old 10-22-2012, 11:55 AM   #14
jdavis96gt's Avatar
Idk cause with that high CR, I think it be bad to super charge it. You plan on running SC or Turbo?
Old 10-22-2012, 02:44 PM   #15
Im thinkin turbo way down the line but also maybe a small shot of nitrous
Old 10-22-2012, 04:44 PM   #16
Coreyw428's Avatar
Region: Arkansas
The higher compression the lower the boost you can run on pump gas, but it's hard to make good hp with a low compression 4.6
---------- Post added at 05:44 PM ---------- Previous post was at 05:43 PM ----------
[QUOTE="Coreyw428"]The higher compression the lower the boost you can run on pump gas, but it's hard to make good hp with a low compression 4.6 without boost
Old 10-22-2012, 10:32 PM   #17
I just really want about 400+ hp. However i need to do that, i want to.. That and my engines all jacked up so i need/want to swap it out or rebuild it anyways!
Old 10-23-2012, 12:58 AM   #18
Coreyw428's Avatar
Region: Arkansas
I'd just get a 03/04 cobra rotating assembly, teskid block, pi heads, stage 2 cams, and trickflow intake, and put a pro charger on it, or some type of centrifugal supercharger.... That would give you what you want and then some, plus when you get bored with it just swap out pulleys and have a completely different car
Old 10-23-2012, 04:48 AM   #19
Alright. That sounds like somethin i can do. How much us that lookin to run me you think?!
Old 10-23-2012, 06:54 AM   #20
Coreyw428's Avatar
Region: Arkansas
I really don't know on the pro charger, they sell kits on most mustang websites, I think even American muscle does, around where I live ppl are sellin 03/04 cobra shortvlocks used for like 1100... Cams usually run about 600 for both, heads, just depends on it you get new or used, not sure on intake either.
Old 10-23-2012, 10:49 AM   #21
So im lookin at like 2500 or so for good quality parts and everything?
08:12 PM
