5.4 swap - Mustang Evolution
Old 10-22-2012, 01:56 PM   #1
5.4 swap
So I finally got lightning engine, I also got a Kenne Bell supercharger. Now what mods do I need to do to drop that beast in my 04 GT?
Edge24X is offline   Reply With Quote
Old 10-22-2012, 01:57 PM   #2
Alot... Engine mounts, wiring, ecu, hood, and some fancy custom work
Old 10-23-2012, 03:32 AM   #3
Check on the wirining, engine mounts and ECU. What's the custom work? Do u mean the exhaust? And will a cobra R hood have enough clearance?
Old 10-23-2012, 03:53 AM   #4
Venomouz831's Avatar
Yes it should
)02 Gt, Founder of WE2G
Old 10-23-2012, 03:56 AM   #5
Coreyw428's Avatar
Region: Arkansas
Idk bout the hood, my buddy has a 5.4 in his with the factory eaton on it and he had 4" cowl and 2" spacers in-between the kmember and frontend
Coreyw428 is offline   Reply With Quote
Old 10-23-2012, 04:00 AM   #6
The cobra r is what 2.5 inches? If he's just gonna do the 5.4 then he shouldn't have a problem
Old 10-23-2012, 06:37 AM   #7
5.4 w/ sc. It's 8-9 inches taller with the sc and plenum
Old 10-23-2012, 10:49 PM   #8
Oh sorry forgot he was going to do the kenne bell
Old 10-24-2012, 03:50 AM   #9
Ok so I need at least a 4" cowl. Now what about the exhaust?
Old 10-24-2012, 03:58 AM   #10
Coreyw428's Avatar
Region: Arkansas
They make headers for a 5.4 swap into a mustang, either that or could just use the manifolds off the lightning and rig the exhaust to match up with them
Old 10-24-2012, 11:19 AM   #11
1996mustang's Avatar
Exhaust for the lightning atleast long tubes is custom ur looking at a stack atleast for lts. Either that or try to find the lts ford racing made for the 4.6 which fit perfectly....however that is a rare find the lts from ford racing
Old 10-24-2012, 02:26 PM   #12
TheNewKid's Avatar
Everyone I see witht he Lightining and KB has to have a huge hole cut in the hood... I dunno whatll cover it
CAI, Off-road H-Pipes, 3.73's and a short throw. UDP and Tuner should be here any day....
TheNewKid is offline   Reply With Quote
Old 10-25-2012, 12:56 AM   #13
Coreyw428's Avatar
Region: Arkansas
You could probably get away with a 4 inch hood and 2 inch spacers in the kmember
Old 10-29-2012, 04:32 PM   #14
any one know what all has to be done to do a 5.4 swap in 99 gt...probly getin a nav, or f150 engine....also if any one has links of how to do this that would be sweet.
Clutch302 is offline   Reply With Quote
Old 10-29-2012, 04:45 PM   #15
Coreyw428's Avatar
Region: Arkansas
The navigator 5.4 is a dohc and I highly doubt it will fit in-between the strut towers without alot of surgery
Old 10-29-2012, 06:06 PM   #16
MELLOWYELLOW06's Avatar
When there is a will, there is a way.
Modified cowl.
Old 12-26-2012, 10:03 PM   #17
Cobraswapv6's Avatar
Just do what i did. Heres my hood i used for 4.6 3v swap and 5.4 lightning swap.
ID:	82813   Click image for larger version
Cobraswapv6 is offline   Reply With Quote
10:56 AM
