wont start - Mustang Evolution
Old 10-22-2012, 02:45 PM   #1
2000steeda029's Avatar
Region: West Virgina
wont start
After a dead battery I'm not getting a spark any ideas?
2000steeda029 is offline   Reply With Quote
Old 10-24-2012, 08:11 AM   #2
96mustangnpi's Avatar
Did you check the fuel pump kill switch in the trunk?
96mustangnpi is offline   Reply With Quote
Old 10-24-2012, 12:02 PM   #3
I smell fuel like its pumping where in the trunk is it its a vert I'll check that anyhow
Old 10-25-2012, 08:19 AM   #4
cliffyk's Avatar
Disconnect the battery for 5-7 minutes and try again (sometimes the PCM Keep Alive Memory gets scrambled when battery voltage gets very low).
Check the crankshaft position sensor:
Disconnect the electrical connector and measure the voltage from each pin (harness side, key on engine off) to the negative battery terminal--it should be 1.0 to 2.0V. If not it is likely a wiring problem, though it could mean a bad PCM.
With the connector unplugged check the resistance between the two sensor terminals (key off, engine off)--it should be 250 to 1kΩ. If not the sensor is bad, however this is not a definitive test as the sensor's output could be weak enough to not register with the PCM.
The good news is they don't cost all that much so while it is not my nature to replace parts and hope I get lucky you may want to just go ahead and replace it...
Old 10-31-2012, 05:22 PM   #5
Well after a hiatus I was able to look at the car today. Battery is fully charged I'm definitely getting spark. I couldn't hear my fuel pump when I turned key to on, checked. So that's my next guess, a few months ago my head unit was stolen and I have yet to replace it could this be it?
03:37 AM
