strange noise when going in reverse after driving on the highway - Mustang Evolution
Old 10-24-2012, 09:29 PM   #1
2002 Ford Mustang GT, TBoneHD32
After a drive of around 55 to 70 miles an hour for an extended period of 20 minutes or more. I put my car in reverse and there is a sound like rubber on metal, and I can feel the sound at the same time coming from rear of car. I replaced all pads, and rotors, and I know I have a leak at my differential pinion seal , but when I changed my diff cover I did not see any metal shavings in the fluid, the fluid did look frothy though. My car also shakes violently when driving between 60-65. I found that all my tires were severely under aired. Haven't driven far since adding air to tires. Pinion seal comes in next week some time. if i want to solve it by myself, does the tool FLY200 scanner can help me?
Any ideas?
hellozaizai is offline   Reply With Quote
Old 10-25-2012, 06:30 PM   #2
sally2002's Avatar
When you changed your diff fluid, did you happen to add friction modifier?
sally2002 is offline   Reply With Quote
Old 03-24-2013, 09:45 PM   #3
i had solved it in a garage
08:22 AM
