need help deciding - Mustang Evolution
Old 10-25-2012, 04:54 PM   #1
Region: Iowa
need help deciding
hey im still new to the site so give me some slack. i have a 4.6l 2v 281 and im building it from the ground up. i have already installed these Forged 4 6L Stroker Rotating Assembly Manley Pistons | eBay and im planning on puchasing trick flow heads. im wondering which cam i should go with, any input? or different approach before i get to far into it to change?
ajbonert is offline   Reply With Quote
Old 10-25-2012, 05:35 PM   #2
Mile high JDF's Avatar
Are you building the motor for boost or are you staying N/A?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 10-25-2012, 07:20 PM   #3
I did the samething you are wanting too but I got my heads CNC ported with comp cams 274 and I love the comp. Check out
southernstang00 is offline   Reply With Quote
Old 10-25-2012, 08:35 PM   #4
Region: Iowa
i am planning on running a turbo later on but not for a little while. when i do turbo it i wasnt planning on running much boost maybe 5 to 8lbs
Old 10-26-2012, 03:49 AM   #5
I'm running a supercharger with mine around 6 psi and I like those cams
Old 10-26-2012, 03:56 AM   #6
Coreyw428's Avatar
Region: Arkansas
A cam made to run a turbo is similar to a n/a cam, so you would be okay gettin like a stage 2 cam or stage 3, just depends on how big of a lope you want the car to have, I really like comp cams but I also like crower cams also
Coreyw428 is offline   Reply With Quote
Old 10-26-2012, 12:44 PM   #7
Region: Iowa
okay thanks, one more question for the newbie what is better a stage 2 or stage 3
Old 10-26-2012, 01:10 PM   #8
Coreyw428's Avatar
Region: Arkansas
Stage 3 is a more agressive cam and will prolly make you have valve releifs in the pistons
10:44 AM
