supercharger questions - Mustang Evolution
Old 10-26-2012, 06:01 AM   #1
04Mstng.GT's Avatar
So I found this rousch supercharger with everything I need for 700 all I need for it is the underdrive pully......wat y'all think
04Mstng.GT is offline   Reply With Quote
Old 10-26-2012, 06:44 AM   #2
Probably the m90. Not the most efficient blower. Don't forget it requires a different lower intake as well as a custom tune
Old 10-26-2012, 07:23 AM   #3
04Mstng.GT's Avatar
Yes I am aware of the tune is it safe to run it on a pretty much stock 4.6 if so what's recommend on how much boost I should run
Old 10-26-2012, 07:50 AM   #4
Titus Wadicus
svtlx's Avatar
im not a mod motor guy... but bn a stock 4.6, i would think 6-8psi. 8psi is really the max unless u r running a large intercooler, and i still wouldnt push it past 8lbs since u dont have any forged internals.
maybe some svt guys can chime n and b more helpful and specific.
just my opinion...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 10-26-2012, 02:30 PM   #5
Matticus's Avatar
I was told anything under 10 psi is safe for a stock bottom end, but personally I would try to stay at 8 or 9.
---------- Post added at 03:30 PM ---------- Previous post was at 03:29 PM ----------
Although it may be less for a bone stock mustang (not sure on that) mine has bolt ons and exhaust, so they may have been going off of that when they told me.
Matticus is offline   Reply With Quote
Old 10-27-2012, 02:31 PM   #6
onesickstang01's Avatar
The tune is the most important part of the whole thing. Make sure plenty of fuel is being delivered and that timing isnt too far advanced. Some guys make well over 450rwhp for years and some only make 400 for a couple weeks. 440 lasted me about 6 months before this...
ID:	73739   Click image for larger version
onesickstang01 is offline   Reply With Quote
Old 11-04-2012, 09:48 AM   #7
04Mstng.GT's Avatar
Ok now would a lightning supercharger fit a gt?
Old 11-04-2012, 11:48 AM   #8
1996mustang's Avatar
No. 5.4 heads are wider apart than 4.6 heads plus its a 4 v
Old 11-05-2012, 08:47 PM   #9
Stang23's Avatar
+1
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
12:42 PM
