Clutch fork counterweight? - Mustang Evolution
Old 10-26-2012, 08:11 AM   #1
Lorraine's driver
ab_mach1's Avatar
I was installing a freeplay mod to my clutch cable yesterday and noticed something I hadn't seen before mounted on my clutch. I took it off to investigate and found that it was just weight. It feels like it weighs around a pound or just over. Anybody know why you would put extra weight on a clutch fork?
Instagram: @ab_mach1
Old 10-26-2012, 08:32 AM   #2
That's weird?
Do you think it is factory or has been added on?
I wonder if that was done to stiffen a weak fork?
Old 10-26-2012, 08:42 AM   #3
Lorraine's driver
ab_mach1's Avatar
Originally Posted by Trojan Horse View Post
That's weird?
It is odd. I does look like it was made for the fork. There's a pre-made hole in the fork for the bolt. It was dirty enough to be factory on the pressure plate side. I can't say for sure though.
Would the weight assist clutching? Would it make a light clutch feel heavier?
Old 10-26-2012, 12:03 PM   #4
That is wierd, but I would bet it has a purpose.
2 thoughts come to mind. First one like trojan said to strengthen it.
Second, maybe to add a little weight so when the clutch isn't engaged it doesn't bounce around?
If its for the second reason then you probably wouldn't need it using the freeplay mod.
Old 10-26-2012, 02:47 PM   #5
I don't see how it could affect the clutch in that way. You won't really feel that small amount of weight and it's not hung in a way that would benefit clutching as far as I can tell. Probably something Ford did to shore up a weak fork?
Old 10-26-2012, 04:01 PM   #6
Lorraine's driver
ab_mach1's Avatar
What I got from a member of the mach1registry was it was for vibration and noise. I guess the weight would dampen the vibration. It could also transfer it somewhere else too.
Old 10-26-2012, 05:01 PM   #7
What material is this weight made out of?
Old 10-26-2012, 05:13 PM   #8
Lorraine's driver
ab_mach1's Avatar
It actually feels like lead.
Old 10-27-2012, 02:24 PM   #9
onesickstang01's Avatar
Yes its for vibration and noise dampening just like the huge weight hanging from the rear diff.
onesickstang01 is offline   Reply With Quote
Old 10-27-2012, 03:00 PM   #10
May be a lead/antimony mix, don't eat any, it is not good for you.
Old 10-27-2012, 04:44 PM   #11
buickregal79's Avatar
Interesting, what ever its real purpose is, i am surprised they don't sell anything like this in the aftermarket if the point is for vibration dampening.
buickregal79 is offline   Reply With Quote
04:14 PM
