Kenne bell automatic - Mustang Evolution
Old 10-27-2012, 10:25 AM   #1
98vertgt's Avatar
So I'm looking to get a kenne bell soon for my 98 gt but when I look at automatics on YouTube they only put down 320-330hp? Could it be because they were dynoing on a mustang dyno or do autos really make less power?
98vertgt is offline   Reply With Quote
Old 10-27-2012, 11:51 AM   #2
Rule of thumb is 15% drivetrain loss for manuals, and 20% for automatics, so yea they make less on the dyno.
Old 10-28-2012, 08:09 AM   #3
Rm360's Avatar
Another reason why the numbers are down a bit is probably that the cars still have the non performance improvement heads and intake , doing a PI swap before the blower upgrade will net you another 30-50 rwhp depending on how aggressive you want to get with the tune
Old 10-28-2012, 09:16 AM   #4
98vertgt's Avatar
I plan on doing a PI swap before I supercharge my car. Think I could get 400hp with full exhaust and a victor jr intake?
Old 10-28-2012, 09:42 AM   #5
1lowGT's Avatar
With just pi heads, full exhaust, and intake? If that's it no. Your need more.
Old 10-28-2012, 09:43 AM   #6
98vertgt's Avatar
What else would I need? I was thinking about putting stage 1 comp cams in when I do the swap.
Old 10-28-2012, 09:49 AM   #7
1lowGT's Avatar
You would need plenty more for a NA motor to get 400hp
Old 10-28-2012, 09:54 AM   #8
98vertgt's Avatar
Oh yeah I know that. I'm saying would a PI motor with full exhaust including lt's and victor jr intake get me 400hp around 8-9 psi or would I need more headwork like cams
Old 10-28-2012, 10:02 AM   #9
1lowGT's Avatar
With PI heads cams intake and FI system 400 hp would be easy.
Old 10-28-2012, 10:41 AM   #10
taylor98gt's Avatar
I wouldn't do pi swap and run a lot of boost cause pi swap raises compression, and higher compression+high boost= bye bye motor. Unless of course you have a built bottom end.
taylor98gt is offline   Reply With Quote
Old 10-28-2012, 12:23 PM   #11
98vertgt's Avatar
I plan on running on the stock bottom end for maybe 6 months but I won't go over 8psi. I'm about to get a good paying job that'll help me make my car the way I want it so one of the first things I'm working on is under the hood.
Old 10-28-2012, 12:40 PM   #12
1lowGT's Avatar
I know onesickstang01 ran I think around 8 psi for 6 months and had stock bottom end until he had problems.
---------- Post added at 01:40 PM ---------- Previous post was at 01:38 PM ----------
Never mind unknown psi but had 440hp
Old 10-28-2012, 01:40 PM   #13
98vertgt's Avatar
That's a little too much for a stock bottom end. My goal is between 390-410hp until I can get a forged bottom end.
Old 10-28-2012, 02:03 PM   #14
1lowGT's Avatar
I would just start from building your bottom end
Old 10-29-2012, 04:06 AM   #15
03whitey's Avatar
03whitey is offline   Reply With Quote
Old 10-29-2012, 10:15 AM   #16
98vertgt's Avatar
I guess it would be smarter to do it all at once
Old 10-29-2012, 10:42 AM   #17
1lowGT's Avatar
Basically. If money isn't such a problem then all at once would be better
Old 10-30-2012, 11:24 AM   #18
infamous281's Avatar
Sell it and get a better 4.6
Thats a waste of money
Old 10-30-2012, 12:42 PM   #19
98vertgt's Avatar
I would if a wasn't attached to my car. I don't mind spending a lot of money to go fast.. It's my baby.
Old 10-30-2012, 01:44 PM   #20
Dude once you get a 99-04 GT you will long forget yours..
I did full bolt ons on my 2001GT and when I got my Mach I was like the hell with 2 Valve GTs .. Stock Mach blows away bolt on GTs..
Dont waste your money.. Your gnna regret it later
Save up for a 5spd GT or a Cobra
Old 10-30-2012, 01:47 PM   #21
98vertgt's Avatar
We'll see what happens after I get this job. I'd love a terminator
Old 10-30-2012, 02:01 PM   #22
Rm360's Avatar
How do you figure that? Mach 1's are rated at 305 fwhp which is about 260 rwhp a 2v gt with full bolt on's with a really good tune can put down 270 rwhp easy if you add ported heads and and stage 2 cams to the mix you would be at 300-320 rwhp , a stock mach 1 wouldn't touch a "full" bolt on gt
---------- Post added at 03:01 PM ---------- Previous post was at 02:57 PM ----------
I've seen stock bottom end 2v running 13. lbs of boost with stage 2 cams and stock PI heads put down 440 rwhp , it's all on the tune to keep it safe , talk to mzilla on here he pretty much had the same setup till he bent a valve
Old 10-30-2012, 04:48 PM   #23
03whitey's Avatar
+100 ^^
Old 10-30-2012, 05:21 PM   #24
Uhm Living proof right here budd.. Youtube Mach 1 vs full bolt on GT
I cant post street racing videos on here -.-
---------- Post added at 06:21 PM ---------- Previous post was at 06:21 PM ----------
Well all my mach has done is Exhaust/STS/Intake/Drags so far..
Old 10-30-2012, 08:05 PM   #25
Rm360's Avatar
#1)in your post you said a stock mach 1 would take a full bolt on GT , it won't
#2) your mach is not stock because of the things you claim to have done , even with your mods you still wouldn't take a full bolt on GT
#3) street racing don't mean a thing , unless its at a track from a stop your vid doesn't prove anything except that street racing is illegal and dangerous
Old 10-30-2012, 08:14 PM   #26
taylor98gt's Avatar
+1000
Old 10-30-2012, 08:35 PM   #27
Lmao your a dumbass dude.. Full bolt on and Fully built are two different things.. Full Bolt on GTs do high 13s low 14s .. Exactly
And who cares I do whatever the hell I want? Have a problem? Go solve it .. Know it all
---------- Post added at 09:32 PM ---------- Previous post was at 09:31 PM ----------
GTs are slow as hell and a waste of money to build NA
---------- Post added at 09:35 PM ---------- Previous post was at 09:32 PM ----------
A fully built GT can barely put out 330 and thats the record..
Have fun with that your close to a stock 4V
Old 10-30-2012, 08:47 PM   #28
Rm360's Avatar
Who said anything about a fully built motor? We are talking stock mach 1 against full bolt on GT , you know what full bolt on's are don't you? You. are right 330 on a NA motor is pushing it that's why 320 is the norm , you know how to read don't you? And the other thing the op is asking about a Kenne bell on a stock motor will your mach put down down more power than that ? I don't think so , do some reading and research before you spew crap out of your mouth you might learn something
Old 10-30-2012, 09:17 PM   #29
1lowGT's Avatar
Easy easy dang
Old 10-30-2012, 09:21 PM   #30
Rm360's Avatar
To the op, I have a all stock PI motor I have two bolt on's , a Kenne Bell 2.1 and a bbk cai I'm putting down 360rwhp , if I do a 75mm throttle body and a 4" cai I would be easily over 400rwhp and the car would be safe to drive as long as you have a good tune, my car was at 380 but we kicked it down a bit due to the throttle body and cai it was becoming a restriction on the top end
ID:	74111   Click image for larger version
Old 10-30-2012, 09:23 PM   #31
Venomouz831's Avatar
I guess it depends in the driver then because my bolt on gt runs low 13's and a tune away from being in the 12's.
)02 Gt, Founder of WE2G
Old 10-30-2012, 09:29 PM   #32
Yeah on a stock Non PI engine thats so pointless..
Go big or go home.. 4 Valves have alot more potiential than 2Vs.. And I didnt say **** against me against a kennebell mustang.. I said full bolt ons stop imagining things
---------- Post added at 10:27 PM ---------- Previous post was at 10:26 PM ----------
Show me or prove to me that A mach would get that much drivetrain loss.. Bull@&#*
---------- Post added at 10:29 PM ---------- Previous post was at 10:27 PM ----------
Yeah go ahead and throw away 2000/3000 dollars just to achieve 300+hp.. My hero
Old 10-30-2012, 09:30 PM   #33
Rm360's Avatar
The op said he was gonna do a PI swap , o ya I forgot you can't read , I agree 4v's have alot more potential but you need to understand that 2v's ain't dogs either you can make big 4v power out of a 2v also
Old 10-30-2012, 09:34 PM   #34
Reading and research ? Oh Jebbbus Im a 4 ASE Certified, Ford/Ford Racing Technician at Mccombs ford here in texas you idiot, I know more than your know it all self.
---------- Post added at 10:34 PM ---------- Previous post was at 10:31 PM ----------
No way , mid 400's tops.. Ive seen plenty of fully built, torktech Blower GTs barely.hit 440s450s .. When you can easily slap a blower with supporting mods and acheive 500-600hp with a 4 valve..
Old 10-30-2012, 09:35 PM   #35
Rm360's Avatar
You do mechanic guy? If so than why I doing math for you 305fwhp- 15% drivetrain loss assuming you have a manual trans = 259.25 rwhp
05:53 AM
