Alternator issue? - Mustang Evolution
Old 10-27-2012, 06:33 PM   #1
RockChalkRR's Avatar
Alternator issue?
So I'm pretty sure I'm having issues with my alternator, but I figured I'd get some opinions. With the car running and lights on, the right side lights are extremely dim and I can't give the car gas at all. Was able to limp home with my headlights off. Exhaust smelled like straight sulfur at first. Check engine light is on.
Am I right thinking my alternator is toast?
RockChalkRR is offline   Reply With Quote
Old 10-27-2012, 10:57 PM   #2
infamous281's Avatar
Get it tested at Auto Zone !
Old 10-27-2012, 11:01 PM   #3
It's not me, it's you.
primer2tone's Avatar
Get in the zone!
Old 10-28-2012, 05:20 AM   #4
Thats weird that only the right side..Was the battery dead when you got home..If you smell sulfur real bad,,your harming the catalytic converter..You can take a meter and put across the battery while its running,,it should be around mid 13 to 14 volts
mymustang is offline   Reply With Quote
Old 10-31-2012, 11:06 AM   #5
Replaced the alternator and battery yesterday, same problem. Car runs fine with the headlights off. Hoping it's just a bad ground.
Old 11-02-2012, 10:26 PM   #6
It was the right headlight bulb. Very strange...
08:31 AM
