Lowering the gt - Mustang Evolution
Old 10-28-2012, 09:14 AM   #1
Doe_Rae_mi's Avatar
Hey guys I'm looking towards lowing my car soon...it's a DD so I don't want to scrape too much. And im definitely paranoid about scraping my bumper lol...how much of a drop would u guys recommend?
Old 10-28-2012, 09:37 AM   #2
1lowGT's Avatar
What's your road conditions. Are there bunch of dips in the road or speed bumps? If you got good roads it should be good for 1.5 inch drop you shouldn't run much on your front bumper it's gonna be your exhuast. I scrape on my h pipe if I don't watch the road dips. Just smart driving you shouldn't scrape much
Old 10-28-2012, 09:43 AM   #3
Doe_Rae_mi's Avatar
I live in the country so it's basically flat. But there is that big bump ever now and then lol
Old 10-28-2012, 09:48 AM   #4
1lowGT's Avatar
Is there any dips in the roads like high spots where tires drive on they sink in the road and cause a high spot right in the center and that's where you'd scrape
Old 10-28-2012, 09:56 AM   #5
Doe_Rae_mi's Avatar
Crap.....the highway I drive on everyday is like that
Old 10-28-2012, 10:00 AM   #6
1lowGT's Avatar
Same here. I just drive slow and cautious.
Old 10-28-2012, 10:06 AM   #7
1lowGT's Avatar
That's how low I am and I can manage to not scrape if you drive smart.
Old 10-28-2012, 08:09 PM   #8
RUNNWLD's Avatar
Region: Utah
What are you lowered on?
RUNNWLD is offline   Reply With Quote
Old 10-28-2012, 09:18 PM   #9
2003mustangGT's Avatar
What's your set up?
2003mustangGT is offline   Reply With Quote
Old 10-28-2012, 09:52 PM   #10
Venomouz831's Avatar
Get coilovers! You can go low one day and the other go like a 1 inch.
ID:	73913   Click image for larger version
)02 Gt, Founder of WE2G
Old 10-28-2012, 11:15 PM   #11
Are the adjustable!? And what's a good place to get them from?
Old 10-29-2012, 08:09 AM   #12
Yes they are. You can have it at stock height or drop it to 3.5 inches. I found my rears in Craig's and the front ones came on the car already. Steeda, Andy's, AM carrys them
Old 10-29-2012, 08:33 AM   #13
1lowGT's Avatar
Would you necessarily need both or could you get just front. Or just back
Old 10-29-2012, 11:12 AM   #14
infamous281's Avatar
Im really low.. Just becareful and roll your fenders
Old 10-29-2012, 11:34 AM   #15
I would suggest both so you can adjust front and back. It helps you tremendously with handling as well.
Old 10-29-2012, 11:53 AM   #16
1lowGT's Avatar
Originally Posted by 2003mustangGT View Post
What's your set up?
Well sadly i dont know.. My car was already lowered when igot it. But it has yellow lowering springs, if that helps i dont know what brand.
---------- Post added at 11:53 AM ---------- Previous post was at 11:52 AM ----------
What brand is yours, and whats the general price range. I know they arent too cheap.
Old 10-29-2012, 11:55 AM   #17
In the front I have Griggs racing coilovers and in the back I have koni yellow coilovers. You can get a good set under 500 dollars
Old 10-29-2012, 01:50 PM   #18
Doe_Rae_mi's Avatar
What are coil overs?!??
Old 10-29-2012, 01:59 PM   #19
This is what wiki said. A coilover is an automobile suspension device. "Coilover" is short for "coil spring over strut". It consists of a shock absorber with a coil spring encircling it. The shock absorber and spring are assembled as a unit prior to installation, and are replaced as a unit when the shock absorber has leaked. This provides for optimal damping without torsional loads. Some coilovers allow adjustment of ride height and stiffness, using a simple threaded spring perch similar to a nut. More advanced adjustable coilover systems will use a threaded shock body, coupled with an adjustable lower mount for ride height adjustment, while an adjustment knob is used to adjust damping, commonly referred to as "stiffness." Spring rate also plays a role in stiffness.
Old 10-29-2012, 02:00 PM   #20
RUNNWLD's Avatar
Region: Utah
Where would be a good set under 500 dollars I can just find some for like 1000 bucks!
Old 10-29-2012, 02:05 PM   #21
Doe_Rae_mi's Avatar
Yea those things are bigggggg money! Lol
Old 10-29-2012, 02:06 PM   #22
Go to horsepower freaks.com and they have a wide selection there
12:30 PM
