strange noise when going in reverse after driving on the highway - Mustang Evolution
Old 10-31-2012, 02:05 AM   #1
2002 Ford Mustang GT, TBoneHD32
After a drive of around 55 to 70 miles an hour for an extended period of 20 minutes or more. I put my car in reverse and there is a sound like rubber on metal, and I can feel the sound at the same time coming from rear of car. I replaced all pads, and rotors, and I know I have a leak at my differential pinion seal , but when I changed my diff cover I did not see any metal shavings in the fluid, the fluid did look frothy though. My car also shakes violently when driving between 60-65. I found that all my tires were severely under aired. Haven't driven far since adding air to tires. Pinion seal comes in next week some time. if i want to solve it by myself, does the tool FLY200 scanner can help me?
Any ideas?
hellozaizai is offline   Reply With Quote
Old 01-16-2013, 11:30 PM   #2
is there anyone can help me?
Old 01-17-2013, 04:40 AM   #3
jdavis96gt's Avatar
Region: West Virgina
Maybe transmission mount is broke or something. When u put in reverse, your tyranny moving a little bit. Maybe exhaust is loose.
Old 01-19-2013, 12:02 AM   #4
JetLife 01GT's Avatar
Any ideas?
Did you ever get the pinion seal on? Have you drove it since you aired up the tire? Shaking between 60-65 could be your wheels aren't balanced. Maybe a bent rim. Not sure what the noise can be. Can you get a video of the sound it's making. Maybe try changing tranny fluid as well. Im not familiar with that scanner tool is. Is your car throwing a code though? If it is, you can get it scanned for free at most auto parts stores.
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
10:10 PM
