Air conditioning compressor - Mustang Evolution
Old 11-01-2012, 02:50 AM   #1
Mean green 91's Avatar
Hi! Everyone I have a 2000 GT and at the end of summer my compressor went out, so I got a new one and it says there is a certain weight oil that goes in it does anyone know what it is?
Mean green 91 is offline   Reply With Quote
Old 11-01-2012, 02:58 AM   #2
It's not me, it's you.
primer2tone's Avatar
Humm, I know it's only a few ounces. But every compressor could be different. If no one chimes in I'd suggest calling the dealer in the morning. And if I remember correctly the stuff I used to use was called Ester oil. I don't know if it comes in different weights.
Old 11-01-2012, 03:06 AM   #3
Ok thanks, I did talk to a dealer tho and they would not give up any info just wanted me to bring it in for them to look at.
Old 11-01-2012, 05:06 AM   #4
onesickstang01's Avatar
Alot of them come pre charged with oil. Make sure it. There should be a tag or paper telling you. If not its just a couple ounces
onesickstang01 is offline   Reply With Quote
Old 11-01-2012, 05:35 AM   #5
Here's a link that might help you.
http://forums.corral.net/forums/gene...-much-oil.html
Old 11-01-2012, 05:42 AM   #6
Bleem@1's Avatar
I'll look it up at work. It should be PAG OIL and prolly 2 oz. I would also suggest adding fluorescent tracer dye to the system.
Bleem@1 is offline   Reply With Quote
Old 11-01-2012, 05:46 AM   #7
Sorry I put weight and didn't even think, but I meant viscosity?
Old 11-01-2012, 05:50 AM   #8
Bleem@1's Avatar
Yeah PAG should be oil type. I will look it up at work. Should post before 9 am.
Old 11-01-2012, 05:52 AM   #9
Also thanks guys I think I got it now didn't really need it right now but wanted to get it done. Thanks again
Old 11-01-2012, 06:17 AM   #10
Xavier9370's Avatar
No problem
Xavier9370 is offline   Reply With Quote
Old 11-01-2012, 08:45 AM   #11
Bleem@1's Avatar
PAG OIL Ford part number. F7az-19589-DA (Motorcraft YN-12-C) that is what you need add same amount as drained from old compressor. Spin shaft six to eight times while collecting old oil from compressor. And I would add one once of fluorescent dye.
Old 11-01-2012, 09:16 AM   #12
Xavier9370's Avatar
Old 11-01-2012, 11:18 AM   #13
infamous281's Avatar
Take it to a shop...
Its most likely contaminated from the air when you replaced it..
They have a machine that will vaccum/recharge your system..
Oil / Freon / Everything..
Old 11-01-2012, 09:56 PM   #14
I redid my a/c on my truck. I flushed the lines out with alcahol to remove moisture, replaced the orphace tube and drier and rented the vacume pump from autozone. Wasn't a bad job just double checked everything.
Cdbformula is offline   Reply With Quote
Old 11-02-2012, 05:43 AM   #15
Bleem@1's Avatar
Denatured alcohol works great or they actually sell ac flush now.
turbo or supercharger sam minnick 1996-2004 Mustang GT 72 10-09-2012 11:27 AM
Intake Suggestions..... Srohda 2011-2014 Mustang GT 42 09-19-2011 03:56 PM
Vacuum lines coming from passenger fender well.? Otlaw80 1979-1995 Mustang GT 3 08-15-2011 07:01 AM
Air Conditioning Help! 01 Mustang GT 'Vert metalplatesrule 1996-2004 Mustang GT 10 07-22-2011 12:59 AM
Air conditioning Sinclairstation Classic Mustangs 1 07-07-2011 07:56 AM
08:35 AM
