Chirping clutch - Mustang Evolution
Old 11-01-2012, 01:08 PM   #1
2003mustangGT's Avatar
Chirping clutch
Got a chirp coming from somewhere but I found that if my foot is completely off the clutch it chirps but If I barely lay some weight on it OT goes away? Any hell?
2003mustangGT is offline   Reply With Quote
Old 11-01-2012, 01:40 PM   #2
Region: West Virgina
Throw out bearing mine did the same thing had to put a new one in
Mustangnutz is offline   Reply With Quote
Old 11-01-2012, 02:17 PM   #3
How much ate those? And where do i get one? AM?
Old 11-01-2012, 02:19 PM   #4
yup Throwout bearing, good time to replace the entire clutch as the trans has to come out to fix.
Its not going to blow up or anything but you need to have it looked at sooner than later.
You can manually take up slack in your clutch to help it for a bit. Push in clutch with left hand, hold right on clutch quadrant (above gas petal you can see it move with the clutch going in/out
Hold tension on the quadrant as you slowly let out on the clutch. It will make a noticeable "click" do that a couple times, petal should be firmer at the top. You want a half inch of pushing in the clutch before the rpms slip.
To test go 45-55 hold gas steady and ease in clutch, if you go more than 1/2 an inch before the rpms jump up you are good.
Old 11-01-2012, 02:24 PM   #5
Ok I'll haw to do that when I get home. And I guess like you said go ahead and replace the whole clutch. Any suggestions on the whole clutch set up? As far as brands and stages and stuff?
Old 11-01-2012, 05:32 PM   #6
bmabbott's Avatar
Yeah... mine's doing the same thing at the moment... but the motor is being pulled this weekend anyways, so I'm re-doing my clutch setup anyways...
I have a Centerforce Dual friction... really like it. I hear good things about HDX too. Pilot bearing and Throwout bearing are cheap on MMR!
I'm ordering my whole cam/exhaust setup from MMR, as well as the 2 bearing listed above... Good luck! That chirping is annoying, so I feel your pain!
*01 Cobra, 4.6L, P&P heads, Stage 3 comp cams, MAC LT headers, O/R Hpipe, Bassani catback exhaust, Too many bolt-ons to list..., 4.30 gears. (364 rwhp/ 330 rwtq)
*01 Roush Stage 2, 4.6L, 5 spd, BBK Bolt-ons (Wife's)
*71 Chevelle, 350, 4 spd, H/C/I, (~400 hp)
*72 C10, 350, Auto, (my Daily Driver)
bmabbott is offline   Reply With Quote
Old 11-03-2012, 12:07 AM   #7
Mmr?
Old 11-03-2012, 12:26 AM   #8
irishn8's Avatar
Maybe he means LMR? (late model restoration)
Old 11-03-2012, 12:46 AM   #9
Thats what I was thinking buy to be sure I asked lol
Old 11-03-2012, 07:59 AM   #10
bmabbott's Avatar
Mmr (modular mustang racing)... Not Lmr
Old 11-03-2012, 06:04 PM   #11
LAS97GT's Avatar
---Las97GT
03:05 AM
