Break/Stop!!! - Mustang Evolution
Old 11-02-2012, 12:26 PM   #1
Israel98's Avatar
Break/Stop!!!
About 3 days ago my 98 mustang turned off right after I got off of the freeway. It was working fine every day before that. When I pulled over I turned it back on and it turned on like a champ. But as soon as I put it in drive or reverse it shut right off. I need as many suggestions as I can get. Thanks.
Israel98 is offline   Reply With Quote
Old 11-02-2012, 07:51 PM   #2
SSC182's Avatar
Is it an automatic?
SSC182 is offline   Reply With Quote
Old 11-02-2012, 08:30 PM   #3
1996mustang's Avatar
I had a similar problem. The question is do u blow a fuse. If so u might wanna check the harness by the egr thats where my problem lied.
Old 11-02-2012, 08:41 PM   #4
It's not me, it's you.
primer2tone's Avatar
You also should check your idle air control valve. I had a bronco II that had the same problem. It was the IAC.
Old 11-02-2012, 09:35 PM   #5
I had a similar problem and it was the wires to the maf. Check the maf out
Mgsgreystang is offline   Reply With Quote
Old 11-03-2012, 03:22 AM   #6
Israel98's Avatar
Yes it is auto. I'll take a look at it today after work i stopped using it because it got worse... I'll let you guys know what I came up with thank you guys for the pics and suggestions. I'll get back to ya ASAP.
Old 11-03-2012, 09:04 AM   #7
SSC182's Avatar
Since its an auto it could also be your torque converter clutch not releasing. It would be like driving a stick and not pushing your clutch in when you stop. Do your brake lights operate.
Old 11-03-2012, 09:55 AM   #8
Israel98's Avatar
Yeah they work fine. I just got the Tranny rebuilt about 4 months ago.
Old 11-03-2012, 12:40 PM   #9
SSC182's Avatar
If you have any way to look at PIDS I would start there so you can actually look at what the TCC and all the other sensors are doing
Old 11-04-2012, 02:06 PM   #10
Israel98's Avatar
Well I had time to see what might have been the problem my mustang had a few days back and it turned out to be the idle control valve. I thank you primer2tone and everyone who replied to my problem good work guys.
07:23 AM
