New guy looking for help! - Mustang Evolution
Old 11-02-2012, 06:48 PM   #1
I have a 2000 mustang gt and I'm having trouble with the second and reverse gears. The second gear is kinda hard to get into, doesn't slide in like the rest and as for my reverse it will only go in when the engine is off. Help please. I recently had a new clutch set installed because no gears where going in.
Call me fez is offline   Reply With Quote
Old 11-02-2012, 06:51 PM   #2
Lorraine's driver
ab_mach1's Avatar
Welcome!
Have you had this problem since the new clutch was installed?
Instagram: @ab_mach1
Old 11-02-2012, 08:50 PM   #3
Coreyw428's Avatar
Region: Arkansas
Sounds like your syncro's or forks are bad
Coreyw428 is offline   Reply With Quote
Old 11-02-2012, 09:56 PM   #4
I've got the same problem. I'll have to check the forks.
jranaudo is offline   Reply With Quote
Old 11-02-2012, 10:43 PM   #5
Originally Posted by Azure
Welcome!
Thanks!
And no the second gear would go in like the rest and the reverse would usually go in
---------- Post added at 10:43 PM ---------- Previous post was at 10:42 PM ----------
How do I check those? Where are they located?
Old 11-02-2012, 10:51 PM   #6
Lorraine's driver
ab_mach1's Avatar
Since you just had the clutch replaced, it could be something simple, like your cable adjustment has changed. Maybe the cable stretched a little. Do you have the stock clutch cable and quadrant setup?
Old 11-02-2012, 11:19 PM   #7
Yes I do. Would I need an aftermarket one with the adjuster on the firewall?
Old 11-02-2012, 11:50 PM   #8
Lorraine's driver
ab_mach1's Avatar
There some little things you can check with your stock cable and quadrant. The quadrant is made of plastic. If it's cracked, it could make it so your clutch is not engaging completely and that could make it difficult to shift into gear. The cable could be stretched out causing the same situation, the clutch not engaging fully. It certainly could be your synchros in your tranny, but it's good to check the simple things first.
Old 11-02-2012, 11:52 PM   #9
Butch's Avatar
Region: New Mexico
Syncros sounding issue. For reverse try going into 5th then reverse
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 11-02-2012, 11:57 PM   #10
I was told of this technique and it'll only work half the time. What are syncros?
---------- Post added at 11:57 PM ---------- Previous post was at 11:56 PM ----------
Will check tomorrow, is there any way of knowing if the cable is stretched?
Old 11-03-2012, 12:09 AM   #11
Lorraine's driver
ab_mach1's Avatar
You can try this procedure to adjust the clutch cable on the stock setup.
Clutch adjustment
Old 11-03-2012, 12:27 AM   #12
Thanks bro this sounds just like my problem, I'll check it out in the morning!!
Old 11-03-2012, 01:03 AM   #13
Butch's Avatar
Region: New Mexico
If I understand correctly its what matches your your gear speed when your shifting.
-----NEHP---
{Never Enough HP}
Old 11-03-2012, 01:04 AM   #14
Coreyw428's Avatar
Region: Arkansas
Thanks!
Really no way to check them, it will just keep getting worse and worse till you won't be able to get it in gear, they have the kits for them but unless you wanna pull the trans I'd say take it to a mechanic or find another trans
Old 11-03-2012, 01:45 AM   #15
1slosix's Avatar
My GT's T3650 had this same issue...turned out to be a bent shift fork. In the end i just had the trans rebuilt. In all honesty i love to do my own work but it seemed like something i wanted professionally done. However my current cars auto will be j-modded by myself come spring cause you gotta learn sometime. Good luck op but i think your issue will be an internal one
carving corners like a boss
Old 11-03-2012, 09:53 AM   #16
Thanks guys. I have all the necessary tools to do it myself just not the knowledge. Lol
Old 11-03-2012, 10:55 AM   #17
Scream's Avatar
Clutch adjustment
Sorry to steal a thread didnt want to make a new post
My clutch is hard to push down it's the clutch cable. But how hard or how much about is it to replace the clutch cable?
Scream is offline   Reply With Quote
Old 11-03-2012, 12:02 PM   #18
Lorraine's driver
ab_mach1's Avatar
IMO, removing the stock spring loaded quadrant is the hardest part because of where it's located. It helps to remove your drivers seat so you can lay on your back easier. Replacing the cable is pretty easy. I can access mine by using a set of ramps. Checkout this posts from cliffyk, and look through his posts on that thread talking about clutch cables and quadrants for more information. He also shows the distance needed to get your throw bearing the right distance from your clutch pressure plate.
I have a Ford Racing adjustable cable. It was $97 at a Ford dealership. Many people like the firewall adjuster and the stock clutch cable. At my Ford dealership, the stock replacement was $94.
You can pickup a Steeda quadrant and adjustable cable from American Muscle.
Steeda quadrant
Steeda adjustable cable
If you want the firewall adjuster type, AM sells a complete kit.
SR Performance clutch adjuster kit
I know the Steeda setup is pretty good. I'm not familiar with the SR setup. I hope this is helpful to you.
Old 11-03-2012, 12:38 PM   #19
Lorraine's driver
ab_mach1's Avatar
Call me fez, how many miles do you have on your Mustang? 1slosix could be right too that in may be an internal problem. I looked in my Chiltons book and it says the 2000 GT's have a T50D transmission by Borg Warner. I can't find much of anything on this tranny online. Maybe it is essentially the same as the T5, not sure.
Old 11-03-2012, 06:15 PM   #20
It's at 147k
10:23 AM
