Replacing my clutch - Mustang Evolution
Old 10-31-2012, 11:38 PM   #1
Nate98stang's Avatar
Exclamation Replacing my clutch
On and anybody with a 99-04 gt have any tips how to get the tops trans bolt out on the driver side dad and I are having a terrible time it's a crazy tight fit
2002 5 speed Comp Orange Mustang GT. K&N CAI,JBA headers,BBK xpipe,SLP mufflers to turn downs,Exedy stage 2 clutch,MGW short throw,drilled and and slotted roters,front:17x9 black 10th anniversary cobras Rear:17x10.5 black 10th anniversary cobras,Roush stage 3 body kit,smoked tails and side markers.
Nate98stang is offline   Reply With Quote
Old 11-01-2012, 12:27 AM   #2
Mile high JDF's Avatar
I think I had like a foot of extensions and a swivel socket. Those bolts sure made for some nice scratches on my arms.have you taken the transmission crossmember off yet?
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-01-2012, 10:03 AM   #3
A swivel socket we havnt tried that yet thanks man, but yea the only bracket left is the one at the back of the trans
Old 11-01-2012, 11:19 AM   #4
Ok. To give myself some room I took of that cross member and lowered the transmission a little bit with the jack.
Old 11-01-2012, 11:22 AM   #5
Gonna be dumb here and the crossmember is the black bar going across correct?, and I would think lowering the trans would put too much tension on the bolt
Old 11-01-2012, 11:24 AM   #6
Coreyw428's Avatar
Region: Arkansas
If you took the cross member out and put a jack or somethin under the trans it would make it alot easier to get the bolt out
Coreyw428 is offline   Reply With Quote
Old 11-01-2012, 11:26 AM   #7
Well ill to take a pic in a moment because I'm not the most me mechanicly inclined person and show u where I took off and go from there lol
Old 11-01-2012, 11:33 AM   #8
Here Is how she sits
ID:	74335   Click image for larger version
Old 11-01-2012, 12:16 PM   #9
Coreyw428's Avatar
Region: Arkansas
Just put a jack toward the back of the trans and take the black brace that is toward the tailshaft on the trans and slowly let the trans down a few inches and that will give you a little extra room
Old 11-01-2012, 12:19 PM   #10
Alright thanks, but wouldn't that put tension on the bolt and bell housing?
Old 11-01-2012, 12:35 PM   #11
Coreyw428's Avatar
Region: Arkansas
A little but not that much as long as you don't let it drop 5 or 6 inches
Old 11-01-2012, 12:36 PM   #12
+1^ as long as you don't reach the limit of how far the motor mounts can stretch you'll be good
Old 11-01-2012, 12:36 PM   #13
Ok thanks
Old 11-01-2012, 01:12 PM   #14
Appreciate the tips guys that's why I love ME very helpful community
Old 11-01-2012, 01:58 PM   #15
jhagan1980's Avatar
Can't he just undo the trans from the bellhousing and lower it? Afterward remove the bellhousing and reinstall on the ground?
jhagan1980 is offline   Reply With Quote
Old 11-01-2012, 03:34 PM   #16
Nope. You can do that for the T5 but not the T45
Old 11-01-2012, 05:36 PM   #17
jhagan1980's Avatar
Ok learn something new everyday.
Old 11-01-2012, 05:59 PM   #18
Ok got all the bolts out I think (7 bolts) then the 4 at the tail what else has to be done can't get it off the engine seems solid still
Old 11-01-2012, 06:04 PM   #19
Coreyw428's Avatar
Region: Arkansas
If you got every thing off the trans, driveshaft, clutch cable, and shifter pulled off and wires undone, you will have to raise it back up to almost level then start pullin and wiggling back and forth till the input shaft finally gives way and slips out
Old 11-01-2012, 06:21 PM   #20
Driveshaft out shifter handle off but shifter base Is there, o2 sensers r unplugged, raising it back up can't get it to move at all, well we can wiggle it passenger side if the trans seems to come away from the dust cover but the driver side won't give at all
Old 11-01-2012, 06:24 PM   #21
Coreyw428's Avatar
Region: Arkansas
If it's anything like mine you'll have to raise it up and down and jerk the **** out of it side to side and every which way to get it to slide out... Just double check everything and make sure nothin is hung, like the passenger side exhaust, or the starter
Old 11-01-2012, 06:30 PM   #22
Starter is off x is off
Old 11-01-2012, 06:36 PM   #23
Faststallion98's Avatar
That sounds about rite
Faststallion98 is offline   Reply With Quote
Old 11-01-2012, 06:52 PM   #24
I would double check both sides, I don't remember any more but I thought there were 8 bolts.
Old 11-01-2012, 06:59 PM   #25
Well got 4 on the driver side 3 on the passenger, 2 dustpan bolts and the passenger side moves more then the driver
Old 11-01-2012, 07:24 PM   #26
Coreyw428's Avatar
Region: Arkansas
You might have to see if you can work a prybar or somethin on the driver side and break it loose... Just be careful cause it could crack the bellhousing if you get to violent
Old 11-01-2012, 07:24 PM   #27
From this picture it looks like 8 bolts
Old 11-01-2012, 07:39 PM   #28
Unless I'm counting the dowel pin holes
Old 11-01-2012, 08:05 PM   #29
She's out!!! Thanks guys hand to pry on one side while dad pryed on the other barley got it out with out dropping it but its out thanks again for the tips guys, and any tips on changing out the throw out and everything else included in the clutch change is greatly appreciated, and Idk about resurfacing my flywheel anyone know what a replacement from a parts store will cost? I tried looking online all it showed was for an auto
Old 11-02-2012, 05:22 PM   #30
Can't seem to get the pilot berring in? Is there a secret to it
Old 11-02-2012, 05:33 PM   #31
Is this correct?
Old 11-02-2012, 05:41 PM   #32
Is this correct?
No, it has to be flush. Did you lube up the outside of the bearing and the inside of your rear main seal? That should help it slide in. Then grab a socket that is just a bit smaller than the outside of the bearing and hammer it in. It's a pretty tight fit.
Old 11-02-2012, 06:28 PM   #33
Does it matter it's a ford racing bearing
Old 11-02-2012, 06:36 PM   #34
If it's flush? Yes it does
Old 11-02-2012, 07:21 PM   #35
Well I was reading around and some guy had my issue with it not being flush and someone told him it didn't need to be? Idk I just want everything to be in working order when we out it back together ik the ford racing one is thicker I believe
Clutch Pedal Height Adjustment and Clutch Freeplay Mod ab_mach1 1996-2004 Mustang GT 126 10-20-2017 03:21 AM
Clutch Adjustment Question? v8pony 1996-2004 Mustang GT 13 10-09-2012 09:57 AM
Clutch, how can i prolong its life? the_stig 2011-2014 V6 Mustang 26 06-16-2012 07:58 PM
If u have air in the break fluid can that make ur clutch pedal feel stiff? bluestorm52 2005-2010 Mustang GT 7 12-10-2011 04:49 PM
Clutch just went 04machazblue 1996-2004 Mustang GT 9 08-24-2011 05:41 AM
12:05 PM
