2002 4.6 gt swap to 1991 5.0 - Mustang Evolution
Old 11-04-2012, 06:32 AM   #1
mustang2323's Avatar
Hey I'm wanting to swap my 4.6 for a 91 5.0. What ALL will I NEED to do so?
mustang2323 is offline   Reply With Quote
Old 11-04-2012, 07:10 AM   #2
Uh...why.
And you'll need everything
Old 11-04-2012, 07:20 AM   #3
My motor is shot! Can't figure out why its missing on the 7 and 8 cylinder. Bout new spark plugs, coil packs, and injectors. Still missing. There is a guy I work with that has a carbed 91 5.0 for 300 bucks...can't go wrong with that.
Old 11-04-2012, 07:25 AM   #4
GHO5T5NIPER's Avatar
Just buy a crate engine?
GHO5T5NIPER is offline   Reply With Quote
Old 11-04-2012, 07:29 AM   #5
Why do that when there is a perfectly fine 5.0 with 30k on it?
Old 11-04-2012, 07:51 AM   #6
Eturner's Avatar
Originally Posted by lowflyn
Uh...why.
+11
---------- Post added at 08:51 AM ---------- Previous post was at 08:49 AM ----------
Originally Posted by Eturner
+11
Is your car a DD?.. If not then save up some cash and get a 4.6 Aluminator motor!.. It bolt right up!..
Old 11-04-2012, 07:51 AM   #7
Jgill1992's Avatar
Because you will spend more putting that motor in than it would cost to buy a whole new car ...
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 11-04-2012, 07:59 AM   #8
Car is a daily driver. I need it fixed ASAP! Just looking for a full list of parts I will need for this swap. Just to see if it is worth my time/money.
Old 11-04-2012, 08:13 AM   #9
JetLife 01GT's Avatar
It's not. I'd really try to figure out what is causing the misfire before a total motor swap. Maybe swing by the dealership or a really good mechanic and see what they think it is. That's a lot cheaper than a motor swap. And if u have to do a swap, swap it for another 4.6 or possibly consider a new car. That motor is not worth time/money/headache. IMO
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-04-2012, 08:15 AM   #10
DaBluedude's Avatar
Lol. This is a huge swap. You need everything from a new fuel delivery system to a new wiring setup, cooling, braking system setup probably... New k member likely too. It's a huge and stupid swap. Engine would cost 300 and the rest of the mods would be another 2500 and the end result would suck. Unless it is a pretty built engine You will have less power. It's a stupid swap and you would be a fool to attempt it. Buy a beater and save up for a proper fix.
2003 Mach 1
Old 11-04-2012, 08:16 AM   #11
+10
2001 GT
Old 11-04-2012, 08:24 AM   #12
98vertgt's Avatar
+11
98vertgt is offline   Reply With Quote
Old 11-04-2012, 01:25 PM   #13
91 was fuel injected. Sounds like an engine full of problems. You would need a different fuel system, trans bellhousing, make a harness, speedo would never work, engine mounts, exhaust, etc. it's not just dropping it in and driving
If you're in an area with smog/inspection it won't pass with a carb
Old 11-04-2012, 02:01 PM   #14
Coreyw428's Avatar
Region: Arkansas
Go to a junkyard and get a 02 up crown Vic, f150 motor, they are 4.6 pi, I picked up 1 3years ago with 79,000 miles for $700 just swap your intake and everything... Usually get them cheaper when you don't mention mustang
Coreyw428 is offline   Reply With Quote
12:40 PM
