Need quick help!!! - Mustang Evolution
Old 11-04-2012, 05:10 PM   #1
Mathew r Wright's Avatar
Need quick help!!!
Ok car ran just fine never had any problems with it running yet. But I just went to leave on lunch and my car won't start? It will continuously crank over but never start??? I looked at my gauges and everything looked fine but oil pressure I notice its not reading any oil pressure.
Mathew r Wright is offline   Reply With Quote
Old 11-04-2012, 05:13 PM   #2
sam minnick's Avatar
I dont think it will read oil pressure until it starts... are you getting fuel
sam minnick is offline   Reply With Quote
Old 11-04-2012, 05:14 PM   #3
When I went to start it the first time the gauge said normal pressure the the needle dropped and so now I have no oil pressure when I try to turn it over??? Note last night I noticed my fuel gauge was getting stuck? It read lil less 3/4 tank, then slowly built up to full tank. Note I also noticed that she has been consuming a lot of fuel lately...
Old 11-04-2012, 05:14 PM   #4
maldog's Avatar
Region: Nevada
I thought you said it won't start? So how can u see the oil pressure? Well any who .......... Fuel, spark and air! The three elements required to run a engine. Start looking at the three to figure what you're not getting. Good luck!
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 11-04-2012, 05:17 PM   #5
Yes gettin fuel checked out ok on gauge...
---------- Post added at 07:17 PM ---------- Previous post was at 07:14 PM ----------
I mean at very first when I went to go on lunch break it acted like it was gonna start and run read fine on gauges then everything just stopped. Well I mean not everything but car just cranks but won't turn over??? I need o2's real bad! Could this be playing a role in it???
Old 11-04-2012, 05:40 PM   #6
Yah I think your right but yes got fuel. It's gotta be something simple because it ran just fine and always has. That's why it just has my mind blown...
Old 11-04-2012, 05:49 PM   #7
1996mustang's Avatar
Check the fuses under the dash. Other than that im sorry to say its either of 2 things ....... oil pressure sending unit or oil pump
---------- Post added at 08:49 PM ---------- Previous post was at 08:48 PM ----------
Easiest would be move around the oil sending unit connection maybe it wiggled loose
Old 11-04-2012, 08:12 PM   #8
You know I didn't think about fuses because I notice I had a tail light out and no cruise I forgot all about that...
Old 11-04-2012, 08:18 PM   #9
DaBluedude's Avatar
Reset your fuel pump relay. In the trunk in the drivers side inside the interior panel. I bet that's it.
2003 Mach 1
Old 11-04-2012, 08:26 PM   #10
Israel98's Avatar
Yeah check the pump switch. As for the oil pressure, you might have a bad oil pressure sensor. They're about 12 bucks at autozone. Looks like this. At least for a 98 gt
Israel98 is offline   Reply With Quote
Old 11-04-2012, 09:45 PM   #11
Well guy sorry to disappoint you but the car started right up like nothin ever happened I don't know it was strange. She just started right up just a min ago thought...
---------- Post added at 11:44 PM ---------- Previous post was at 11:42 PM ----------
Wow that's cheaper than I imagined thanks for the pic and everything
---------- Post added at 11:45 PM ---------- Previous post was at 11:44 PM ----------
Oh and welcome! also great lookin car!
Old 11-04-2012, 09:52 PM   #12
Israel98's Avatar
Wow that's great hopefully it stays like that. Good luck and no problem.
12:42 AM
