Oil is coming out my rear diferential ! - Mustang Evolution
Old 11-04-2012, 06:05 PM   #1
Xavier9370's Avatar
Hey guys, I need your help.
I just notice my car is leaking oil from the rear diferential on the bottom.
What do you guys think is happening ?
---------- Post added at 08:05 PM ---------- Previous post was at 08:03 PM ----------
It has 88k miles and I just bought it so I don't know any history of repairs, oh is manual in case if it matters
Xavier9370 is offline   Reply With Quote
Old 11-04-2012, 06:35 PM   #2
Tyoung68's Avatar
Probably a gasket clean it all off and then look to see wheres it leaking from
Old 11-04-2012, 06:36 PM   #3
Silver Pony's Avatar
Probably just a Gasket. Replace it. That's what I'm doing next week for the same thing. Noticed a few drops on my garage floor.
Silver Pony is offline   Reply With Quote
Old 11-04-2012, 06:44 PM   #4
Xavier9370's Avatar
About the size of a hand within 2hours
---------- Post added at 08:44 PM ---------- Previous post was at 08:43 PM ----------
I'm so concern I'm afraid to drive it to the shop, it it safe to drive it?
Old 11-04-2012, 06:45 PM   #5
I wouldn't drive it.
Old 11-04-2012, 07:02 PM   #6
TheLastDraggin's Avatar
+1
TheLastDraggin is offline   Reply With Quote
Old 11-04-2012, 07:06 PM   #7
Check the fluid level..If its not dripping its prob hasnt lost alot..Probably just a gasket like eveyone said...I always reseal with silicone..
mymustang is offline   Reply With Quote
Old 11-04-2012, 07:14 PM   #8
Xavier9370's Avatar
Ok thanks
Old 11-04-2012, 09:38 PM   #9
Tyoung68's Avatar
Where is it leaking from? Like on your diff?
Old 11-04-2012, 09:49 PM   #10
Xavier9370's Avatar
Yes on the bottom
Old 11-04-2012, 09:56 PM   #11
Tyoung68's Avatar
Bur from where in your diff? If its coning from the front is the pinion seal and if only on you bottom then its you diff seal
Old 11-05-2012, 05:26 AM   #12
Xavier9370's Avatar
The oil is not coming from the bottom of the cover I just had a good look and is coming from around the part that joint to the u joint of the drive shaft
So what that means? Is it a bigger problem ?
Old 11-05-2012, 05:29 AM   #13
Xavier9370's Avatar
Old 11-05-2012, 06:22 AM   #14
Gonna have to gut the rear completely...
Old 11-05-2012, 07:42 AM   #15
Tyoung68's Avatar
Your going to have to take the drive shaft off take off the thing the drive shaft bolts to on your rear end and theres a seal that needs to be replaced I'm pretty sure its called the pinion seal. Just look it up on youtube and I'm sure you would be able to do it with the right tools
Old 11-05-2012, 04:15 PM   #16
Xavier9370's Avatar
Ok got it
Old 11-05-2012, 04:21 PM   #17
LAS97GT's Avatar
Last I had the stock cover, I dumped the gasket and used just RTV. It worked. If your so worried put a little oil in the diff or have it changed, it's about time too. No worries. Just drive. If it dripping to the ground, replace the gear oil while resealing the cover properly. No worries.
---Las97GT
Old 11-05-2012, 07:31 PM   #18
Xavier9370's Avatar
Thanks that was exactly what it was.
I didn't do it cause I can't do mechanics but I took it to a shop here in Orlando fl powered by ford and they charge me $160
Thanks for the help!
06:33 AM
