Weird noise from shifter - Page 2 - Mustang Evolution
Old 11-09-2012, 06:53 AM   #36
AgentOrange's Avatar
Originally Posted by NJstanger
Have you guys come across any type of picture or something of the actual drain plug...like I said I'm gonna pickup all the necessary supplies today and don't wanna pull the wrong plug
Its the only one on the trans that faces directly down. Look toward the back near the driveshaft, and you'll be confident when you see it. It will probably be tight, as the factory uses loktite on it. If it still flips you out snap a pic and upload it and we'll verify you have the right one
AgentOrange is offline   Reply With Quote
Old 11-09-2012, 08:24 AM   #37
Mile high JDF's Avatar
Originally Posted by AgentOrange
I think Tremec amended their old fill recommendation. Going to the fill plug is about 4 qt, where they now say 3.2 is the optimal amount.
Hm ok.
- Silver 2007 Corvette
Current - DHG 2001 Bullitt
Old 11-09-2012, 08:33 AM   #38
Originally Posted by JDF
Hm ok.
... there's a Ford TSB on this. Just making sure he does everything right.
Old 11-09-2012, 08:39 AM   #39
Good. I have a T45 so I figured they were the same.
Old 11-09-2012, 07:20 PM   #40
Region: Arkansas
fluid amount
Agent Orange is correct.
3.2 quarts is the recommended amount to reduce the nibble felt when shifting into 3rd gear (it doesn't help) but a trick that has been posted all over the web a few years back was to use 3 quarts of fluid and .2 quarts of Lucas synthetic trans fluid.
When it comes to fluid, I personally have used
1)Red Line ATF D4,
2)B&M trick shift,
3)Royal Purple Synchromax and finally
4)GM Synchromesh.
And yes you read that right, GM Synchromesh. Now for me, the 2 best used were the GM followed by the Royal Purple.
I don't have anything bad to say about the others just that it didn't cure my nibble feel when shifting from 2nd to 3rd
Your best bet would be to call Tremec at 1-800-401-9866 to get their opinion. i can tell you now that they will tell you to use Mercon III and their website will say Mobil1 ATF.
the only problem is that most synthetics are to slippery for use in todays manual transmissions.
Good Luck.
GOFAST is offline   Reply With Quote
Old 11-10-2012, 08:34 AM   #41
v8pony's Avatar
So do I have to pull the fill plug as well as the drain plug?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-10-2012, 08:49 AM   #42
v8pony's Avatar
Is this my drain plug???
2002 5spd GT
Old 11-10-2012, 09:53 AM   #43
Grab a pic from a little further away for us
Old 11-10-2012, 10:24 AM   #44
v8pony's Avatar
It was def my drain plug cuz a lot of tranny fluidcame out, but now it's time for me to fill it as the fill Hole in the shifter still had fluid in it, tried to put Some in and it overflowed..help please
2002 5spd GT
Old 11-10-2012, 10:28 AM   #45
The small socket in the center's not a fill hole. Just fill into that case and it will drain down. That hole in the center is what connects to the shifter and controls the trans.
Old 11-10-2012, 10:29 AM   #46
v8pony's Avatar
Should I drain some out of that hole now than?
2002 5spd GT
Old 11-10-2012, 10:30 AM   #47
No. If you look at your shifter it has a pivot ball that fits in there. It'll just move whatever fluid filled it up when you reinstall the shifter
Old 11-10-2012, 11:42 AM   #48
v8pony's Avatar
Awesome Im done!!!! I've never even changed the oil of a vehicle before and thanks to you guys here at ME I just successfully changed my tranny fluid!!! So back to original point of this thread...the change did fix my very very notchy/Grindy 1-2 gear change and 2-3 that is common for the t3650, but the weird vibration/rubbing noise in 5th gear is still there...idk what it could be, it drives perfectly fine the noise just gets to me, I'm hoping its something simple like the rubber boot or something is rubbing along the shifter in 5th gear or something......also I couldn't find penzoil syncromesh so I went with about 3.2 quarts of Mobil 1 synthetic ATF, I'm reading some people swear by it and its what tremec recommends, but than I've read people say do not use Mobil 1 atf synthetic. Am I alright with it?
2002 5spd GT
Old 11-10-2012, 12:03 PM   #49
Very glad to hear you completed your first shot at working on your car. As for the fluid, if you called Tremec right now, they'd recommend that exact stuff. You'll be fine
Old 11-10-2012, 03:08 PM   #50
v8pony's Avatar
Must say its a great feeling and satisfaction of working on my own vehicle, much more to come, oil change the next few days, than a coolant flush possibly if needed. I wanna tackle the basic maintenance before anything, eventually I'd love to really know my way around my engine and tackle repairs without the costly labor rates around here
2002 5spd GT
Old 11-10-2012, 03:11 PM   #51
JetLife 01GT's Avatar
The feeling only gets better the more you do! And it's one of the best feelings! Glad to hear you're getting closer and more familiar with your car.
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-10-2012, 03:36 PM   #52
There is only one issue with working on your car; the more comfortable you get working on it, the harder it is to stop buying parts!
Old 11-10-2012, 03:38 PM   #53
SO TRUE
2001 GT
Old 11-12-2012, 08:08 AM   #54
Region: Arkansas
Good Job
Now that you have been bitten by the DIY bug, be careful. It will consume you. Trust Me. I am in the final stage of my 5.4 swap (and my wife is pissed). But wow is it fun.
Rodney
Old 11-12-2012, 02:38 PM   #55
Rodney
Let's see some pics! That's gonna be an awesome swap!
2001 GT
05:47 PM
