Mach Sound System - Mustang Evolution
Old 11-05-2012, 05:18 PM   #1
Mach Sound System
Help with why the front speaker amp cuts out when close to half volume?
thompson1693 is offline   Reply With Quote
Old 11-05-2012, 11:58 PM   #2
JetLife 01GT's Avatar
Is your system totally stock? Head unit and all
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-08-2012, 11:45 AM   #3
Yes
Old 11-09-2012, 03:15 PM   #4
v8pony's Avatar
Convertible? Reason I ask is because I had the problem until the bass just eventually stopped working, turned out to he a leak in the back of my vert I didn't even know about that shorted and killed my amps
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-10-2012, 12:33 PM   #5
Its a hardtop. The amp for the front just cuts out, the unamplified sound still works but the amp cuts out. I think the reason is it gets too hot. But I just dont know for what reason. I got a used one from a used parts place in South Carolina and replaced it and it does the same thing. In the trunk it is the one on the left. Under the sound chamber for the rear speakers. So you are saying it could be a partial short in the wiring somewhere?
Old 11-11-2012, 06:52 AM   #6
v8pony's Avatar
That would be my best guess, something's going on in the wiring, by you using a seperate amp and its doing the same thing shows its most likely not a problem with the amp itself
2002 5spd GT
Old 11-12-2012, 04:36 AM   #7
I was hoping that was not the problem. Hate to start digging into the wiring, it could be anywhere. The wiring from front to back runs under the doors under the molding right? Any suggestions where to start?
07:13 PM
