Weird noise when turning - Mustang Evolution
Old 11-06-2012, 04:54 PM   #1
03fastblack's Avatar
Ok so I just put camber bolts on my car and its been a week. Now when I turn it makes a loud popping noise and kinda when I brake too. Could this mean that they have came loose or what?
03fastblack is offline   Reply With Quote
Old 11-07-2012, 12:49 AM   #2
Mfore33's Avatar
I would definitely get it checked out soon. Don't want anything falling off while driving causing big costly repairs.
Old 11-07-2012, 12:58 AM   #3
It's not me, it's you.
primer2tone's Avatar
After you installed the bolts did you get the alignment done?
Old 11-07-2012, 12:59 AM   #4
Venomouz831's Avatar
Did you tighten em well?
)02 Gt, Founder of WE2G
Old 11-07-2012, 07:57 AM   #5
No it hasn't been aligned that was gonna happen this week.
Old 11-07-2012, 09:41 AM   #6
Well, get your alignment and see if that clears it up.
Old 11-07-2012, 07:17 PM   #7
1996mustang's Avatar
Sounds like strut mount bushings depending where the popping sound is coming from
Old 11-08-2012, 10:33 AM   #8
I figured it out, the camber bolt weren't tight enough.
Old 11-08-2012, 10:52 AM   #9
That's what I though
01:37 PM
