Won't run when i fill up with gas?? - Mustang Evolution
Old 11-08-2012, 02:53 PM   #1
Fatboy scott's Avatar
This will probably sound weird! Has me baffled. 2002 GT 5 speed vert. Every time I fill up with gas won't run. It will start and then die. I have to keep it idled way up to get out of the parking lot. After 5-10 min it will run fine. And this only happens when I fill up with gas???? Any ideas?
Fatboy scott is offline   Reply With Quote
Old 11-08-2012, 07:22 PM   #2
Harper's Avatar
vapor lock?
gas cap?
2003 COBRA/2004 GT w DOHC Cobra Engine and trans/5spd. IN PROGRESS
67 Mustang Coupe.
1965 F100 w/EFI 5.0 w 5spd.
Harper is offline   Reply With Quote
Old 11-08-2012, 07:26 PM   #3
1996mustang's Avatar
Probably has something to do with ur emissions system possible purge solenoid or evap canister id start checking a diagram of the evap system to see what could cause it to cut fuel off to it.
Old 11-08-2012, 07:32 PM   #4
Shouldn't that cause the check engine light to come on tho? I have no trouble codes at all.
Old 11-08-2012, 07:37 PM   #5
NewMtang's Avatar
Fix...
1) Get hose.
2) Drain out 1/2 tank of gasoline.
3) Take car to nearest Ford Dealer.
4) Trade in Old Car for Newer Model.
5) Problem Fixed.
Old 11-08-2012, 09:14 PM   #6
Scream's Avatar
I have the same problem well similar are your running 93 like me?
Scream is offline   Reply With Quote
Old 11-08-2012, 10:37 PM   #7
Originally Posted by NewMtang
1) Get hose.
5) Problem Fixed.
Also bring $25,000 or a $800 note a month.
Ryan7racin is offline   Reply With Quote
Old 11-09-2012, 12:03 AM   #8
Venomouz831's Avatar
Lol if it was just that easy
)02 Gt, Founder of WE2G
Old 11-09-2012, 12:09 AM   #9
It's not me, it's you.
primer2tone's Avatar
1) Get hose.
5) Problem Fixed.
This guy^ lol
Old 11-09-2012, 12:30 AM   #10
Yeah running 93. Guess I'll talk to the ford mechanic and see of I can come up with anything. And my 16 yr old daughter drives this car. I don't like not knowing what the problem is.
Old 11-09-2012, 05:52 AM   #11
Scream's Avatar
My friend was wanting me to look in to maybe 93 isint good for the car i ignored it asked my dad he said it was prob throttle body or IAC
Old 11-09-2012, 06:40 AM   #12
AgentOrange's Avatar
You have to consider what variables are changing when the problem occurs. Filling the car with gas doesn't effect the IAC in any way, so i'd rule that out and focus on the back half of the car.
AgentOrange is offline   Reply With Quote
Old 11-09-2012, 10:57 AM   #13
Scream's Avatar
True but even after I fill up and get to about half a tank still has a rough idle sometimes
Old 11-09-2012, 11:25 AM   #14
That is a strange issue. I'm guessing it is EVAP related. Does the car act like it has a vacuum leak?
Old 11-09-2012, 01:20 PM   #15
Scream's Avatar
Maybe .. If that means the RPM's are going up and down irregularly I'll be idling at say 1k drop to 600 then up to 1.5k sometimes it is weird
Old 11-09-2012, 02:56 PM   #16
Israel98's Avatar
If its idling up and down you need to clean the idle control valve with carb cleaner. I had a similar problem. I cleaned the idle control and egr and it fixed my problem of the mustang turning on, staying on, then getting close to my destination starting to turn off. Also, clean the throttle intake, not body. Behind the intake build up from gas not being burned builds up. When your at a stop the intake has to be open a little to keep it idled but if has trouble doing so because of the build up. It took me some days to get mine back up. I used to put 93 on it and went to unlead after the problem. Try cleaning these parts it doesn't hurt to try.
Israel98 is offline   Reply With Quote
Old 11-09-2012, 03:02 PM   #17
Scream's Avatar
I cleaned the idle air control valve helped a lol so after I just bought a hole new one. To clean the throttle intake do I need to get in to the throttle body itself?
Old 11-09-2012, 03:12 PM   #18
Israel98's Avatar
To clean the throttle intake take off the CAI and its not necessary to take of the body but if you want you can I just took these screws of and there you have it. Make sure u unhook the response.
Old 11-09-2012, 03:17 PM   #19
Scream's Avatar
Sweet thank you! Ima give it a try soon!
Old 11-09-2012, 03:22 PM   #20
Israel98's Avatar
Yeah no problem. When you do it, your gonna be like damn that's dirty. Haha. Well idk about yours. Mines a 98
Old 11-09-2012, 08:50 PM   #21
Scream's Avatar
Mine is a 02 and previous owner SUCKED didn't take care of her at all!
Old 11-10-2012, 03:58 AM   #22
Israel98's Avatar
Yeah mine to but all we can do is take care of them for Their abuse.
Old 11-10-2012, 11:28 AM   #23
Scream's Avatar
Judy need to take care of idle and paint and I'm already broke and dad won't help (only 17) I work but I give him half paychecks to pay for this pony. Oh well lol
Old 11-10-2012, 12:25 PM   #24
v8pony's Avatar
Same boat man but I'm 21...I made the down payment, he makes the payments, I give him half my paycheck a week, which leaves me broke after normal weekly expenses, sucks but I guess when my car is paid off next year than ill have some real money to throw at the pony
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-10-2012, 12:44 PM   #25
Scream's Avatar
I got a lil over 3k left iv paid about 2.7k back lol
03:40 PM
