Lowering questions - Mustang Evolution
Old 11-09-2012, 09:13 AM   #1
2000_gt's Avatar
Lowering questions
What do I need to buy to lower my car for best looks and ride quality.
2000_gt is offline   Reply With Quote
Old 11-09-2012, 09:20 AM   #2
if you want to maintain ride quality you will want to avoid super stiff springs. Eibach makes a softer rate spring near stock, your stock rate should be 400-450ish.
A progressive spring is a softer ride but when the spring gets pushed down the more its pushed down the harder it pushes back (that means the rate gets stiffer)
usually these ride better overall, but look into eibach and find their rates.
You will want at least 1.5" drop all around to notice a difference. You will need CC plates
for alignment and I recommend doing it right and going with the 4 bolt maximum motorsport plates. You can install all this on your own with a friends help as well, not a bad way to go (there is a how to I wrote in the article section)
Old 11-09-2012, 09:46 AM   #3
98vertgt's Avatar
+1
The CC plates are a must. I didn't get them after I lowered my car for 6 months and my tires were ruined. Maximum motorsports are the way to go
98vertgt is offline   Reply With Quote
Old 11-09-2012, 09:56 AM   #4
2000_gt's Avatar
So what shocks do i need to get
Old 11-09-2012, 10:24 AM   #5
98vertgt's Avatar
I have tokico blues on mine and love them to death
Old 11-09-2012, 12:33 PM   #6
if the shocks are in good shape and the spring rate is close to stock the OEM ones will be fine, but if you want new ones just get some nice OEM style ones. Since you dont care about handling but ride quality they will be fine.
Old 11-09-2012, 03:40 PM   #7
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
These guys have definitely pointed you in the right direction! Springs, Shocks/Struts and CC plates is the ultimate suspension set up for daily driving and drive ability.
Check out our Suspension page and let me know if I can be of any assistance!
-Dan
Old 11-09-2012, 06:06 PM   #8
infamous281's Avatar
Cut Emm
Old 11-09-2012, 09:36 PM   #9
1996mustang's Avatar
Originally Posted by Slow2V
Cut Emm
I think hed rather not bounce around like a honda lol
Old 11-09-2012, 11:03 PM   #10
Sonicblue11's Avatar
I'm on H&R supersport with tokico shocks and struts, they feel all around stuff as hell and great ride quality
Sonicblue11 is offline   Reply With Quote
Old 11-09-2012, 11:14 PM   #11
JetLife 01GT's Avatar
No cc's or camber bolts?
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-09-2012, 11:34 PM   #12
1slosix's Avatar
Originally Posted by Slow2V View Post
Cut Emm
agreed this is a great way to get a good lowered stance and still have a great spring for weight transfer.
I'm guessing you've never cut a set of mustang springs? If you know what you are doing when cutting one and doing it correctly your finished product is a lowered car that will hook nicely thanks to great weight transfer. In fact some of the fastest mustangs i know love either a cut spring or some 4 cyl fox springs cut.
The trick is using a cutting wheel thats made to cut metal..so either an all metal or bi-metal cutting wheel is a must. Never use a torch...heating a spring to cut through it will kill it's temper and make the coils worthless (i.e. dead).
@OP In the end it depends on what you want to do with the car in the end. a drag car is going to be set up way different from a corner carver. There are happy mediums however those mediums never make you awesome in either one. So think it over before you start making purchases.
here's an example...cut 1.25 coils off the front and 1 coil off the back. No ISOs
carving corners like a boss
Old 11-10-2012, 09:58 AM   #13
U are correct good sir i have never cut springs on a mustang. I just dont like the idea of probably compromising the structure of a spring so i usually just change them to something id be satisfied with withing the prospective specs for dampening and spring rate. I guess im just paranoid if u call it that
Old 11-10-2012, 10:09 AM   #14
98vertgt's Avatar
Love em
Old 11-10-2012, 03:16 PM   #15
Originally Posted by 98vertgt
Love em
Same here man
Old 11-16-2012, 05:19 PM   #16
ToHellAndBack's Avatar
I recently replaced my front struts with stock replacements (in the last 2 months cuz I bent em) but I want to get lowering springs. Do I have to replace them again to work with my springs?
"I'm not tailgating... I'm drafting"
ToHellAndBack is offline   Reply With Quote
Old 11-16-2012, 11:42 PM   #17
You should be good unless you're planning to take your car to the track. Then look to upgrade struts. You haven't had them long so you'll be alright. Might wanna look into shocks tho
2001 GT
Old 12-03-2012, 06:43 PM   #18
2000_gt's Avatar
What springs can I use to get the lowest drop with out replacing my shocks and how low will that get me I want it to sit even too if all possible and will I have to have cc plates
Old 12-04-2012, 04:04 AM   #19
Probably about an inch and you'd be okay without replacing shocks but I'd still consider some new shocks. A lot of it has to do with the age of your shocks. I'd recommend getting new shocks if you're past 100k miles and not even lowered. For c springs are about an inch I believe. At an inch you won't need cc plates. IMO an inch isn't enough tho. So I'd opt for lower springs like eibach sports or H&R sports. If you drop more than 1.75-2" look into getting cc plates or camber bolts atleast
2001 GT
Old 12-04-2012, 06:37 AM   #20
Scream's Avatar
How much to have it pro installed? Anyone know
Scream is offline   Reply With Quote
Old 12-04-2012, 08:03 PM   #21
No need for all of that! You can do it
Old 12-04-2012, 08:18 PM   #22
Scream's Avatar
17 with like NO Knowledge lol
Old 12-04-2012, 08:21 PM   #23
Venomouz831's Avatar
It's super easy. My ex gf did it on her charger basically same
)02 Gt, Founder of WE2G
02:00 PM
