Help with 2000 GT! - Mustang Evolution
Old 11-09-2012, 09:55 AM   #1
Zman1992's Avatar
Help with 2000 GT!
I have a 2000gt only mods are pulleys and a cai. I washed it recently and gave the engine a spray to remove some of the dirt and grime and now engine sputters and dies when I hit the gas. The dial jumps to 6k but sounds like it stops at around 3k. When idling it holds at 700 for about 10 seconds then jumps to 1000 then back down to 700.
Zman1992 is offline   Reply With Quote
Old 11-09-2012, 10:03 AM   #2
Rosco's Avatar
Did you wash the engine? Like with a pressure washer? And if you did, did you cover the electronics like coil packs, fuse box, etc. if you did you may have just loosened a connection. Check your spark plug cables at the coil packs by unplugging and re-plugging. Look at all the sensors and connections and make sure their plugged in and check the fuel injectors.
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 11-09-2012, 10:35 AM   #3
Zman1992's Avatar
All checked and all are secure. I unplugged and replugged just to be safe and I still have the issue. I can get it to drive but when I punch it in any gear it jerks hard.
Old 11-09-2012, 10:50 AM   #4
Sometimes the maf connection can cause problems similar to that. Check that out
Mgsgreystang is offline   Reply With Quote
Old 11-09-2012, 11:03 AM   #5
Loc: Austin,TX
Pull the plugs and blow them out with air. They may have water in them.
Old 11-09-2012, 11:07 AM   #6
Venomouz831's Avatar
MAF
)02 Gt, Founder of WE2G
Old 11-09-2012, 11:08 AM   #7
Israel98's Avatar
Check and see if the wash accendentaly didn't disconnect any of the vacuum lines. Check by the idle control valve. Maybe one of the lines is getting air causing your mustang to drop the idle or even shut off.
Israel98 is offline   Reply With Quote
Old 11-09-2012, 11:18 AM   #8
fomoco4life's Avatar
Sounds like MAF.....gotta b careful sprayn water under the hood...i just keep my motor lookn used n dirty....lol
Old 11-09-2012, 11:21 AM   #9
Eturner's Avatar
+11. MAF!...
Old 11-11-2012, 09:56 PM   #10
Zman1992's Avatar
Don't know exactly what it was but I took care of the MAF. Put fuel injector cleaner in the gas and slapped some new plugs in her and she runs like a champ now.
Old 11-11-2012, 10:58 PM   #11
Adogg's Avatar
yea could have been the spark plug just be careful when cleaning use a rag and cleaner
Old 11-12-2012, 06:36 AM   #12
When ever i spray the engine down,,i always take compressed air and dry everything off,,also coil over plugs are bad about catching water
mymustang is offline   Reply With Quote
Old 11-13-2012, 11:54 AM   #13
rodrigo9's Avatar
Im kind of having the same problem im not sure did your engine sign blink?
rodrigo9 is offline   Reply With Quote
Old 11-14-2012, 12:28 PM   #14
Zman1992's Avatar
The check engine light did not come on.
Old 11-14-2012, 12:36 PM   #15
Poopyhead44's Avatar
Mine spits and sputters to if I wash it but it clears up on its own after a few miles
Poopyhead44 is offline   Reply With Quote
what does it take to outrun a GT? austinknoll Pre-2005 V6 Mustang 72 01-14-2012 01:19 PM
my 04 gt, vs 03 cobra and 2011 mustang gt secomejia 1996-2004 Mustang GT 57 01-04-2012 08:07 AM
FS: 2011/12 Mustang GT Strut Tower Brace Napoleon85 Mustang Parts for Sale and Wanted 0 12-22-2011 01:14 PM
2000 mustang GT Mean green 91 General Mustang Discussion 4 08-01-2011 08:49 AM
1966 Ford Mustang GT Fastback Raffle to Protect Children jdipietro ME Site Help & Announcements 1 07-01-2011 04:43 PM
04:20 AM
