Shutters under load - Mustang Evolution
Old 11-10-2012, 02:39 PM   #1
Rockpanama's Avatar
Shutters under load
Hey everyone. I have an 03 gt and it has recently started shuttering under load but clears up after I get the Rpm up. Any guesses?
Rockpanama is offline   Reply With Quote
Old 11-10-2012, 03:08 PM   #2
JetLife 01GT's Avatar
Plugs or cops? Does it feel like the motor is running rough or misfiring? Also manual or auto?
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-10-2012, 08:12 PM   #3
1996mustang's Avatar
When u say shudders does it feel from the rear of the car or front. It could be what happened to me was i was low on diff lube and it shuddered when i got on it a bit or normal driving at times.
Old 11-10-2012, 10:53 PM   #4
02utahgt's Avatar
Region: Utah
Mine did the same thing. After changing everything it ended being the trans mount . It would vibrate even sitting still.
02utahgt is offline   Reply With Quote
Old 11-11-2012, 08:09 AM   #5
Rockpanama's Avatar
I thought it was the clutch so I changed it. Fortunately the clutch was worn out but that didn't fix the prob. It happens in 2nd thru 5th if rpms are low and under load. It feels like it is coming from the back but I can't be sure.
Old 11-11-2012, 10:25 AM   #6
I would check ur differential fluid ur probably low on it. Mine did it and i refilled it
Old 11-11-2012, 12:42 PM   #7
Rockpanama's Avatar
Thanks for all the advice. I will check it and let you guys know what I find out.
07:52 PM
