Purpose of caster/camber plates? - Mustang Evolution
Old 11-12-2012, 01:17 PM   #1
StangerBanger04's Avatar
I went to get my car aligned today and there was another mustang there that was getting Maximum Motorsport caster/camber plates and the guy at the alignment shop said they're really good for lowered cars. What's the purpose of them and are they a good buy?
StangerBanger04 is offline   Reply With Quote
Old 11-12-2012, 01:22 PM   #2
Venomouz831's Avatar
If you're lowered a lot of people will recommend them. Reason is if it's unaligned you're tired might wear faster. They allow you to alight it back to factorry specs
)02 Gt, Founder of WE2G
Old 11-12-2012, 02:34 PM   #3
Did you have them on your car cause I know your car was lowered? Worth buying?
Old 11-12-2012, 02:50 PM   #4
JetLife 01GT's Avatar
Many people say they can get just camber bolts and get their alignment right. I have my H&R springs sitting in my garage waiting for me to put them on. But I can't decide whether I'm gonna go with cc's or c bolts
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-12-2012, 03:47 PM   #5
Yea I had maximum motorsports cc plates and they are worth it
Old 11-12-2012, 06:28 PM   #6
Stang23's Avatar
I have them on my car and there definitely worth it. Keeps the alignment in check and your tires from wearing
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 11-12-2012, 10:04 PM   #7
How long do you think it keeps you from having to get new tires? Couple months? Years?
Old 11-12-2012, 10:39 PM   #8
Once you get the alignment right with cc's, they will wear normally. Doesn't make ur tires last longer or shorter than normal. It's when the alignment is all off that causes abnormal and premature wear on ur tires. I believe the average tire is made to last around 40k ish depending on how you drive.
2001 GT
Old 11-12-2012, 10:57 PM   #9
My friend got around 10k out of his tires unaligned and cambering
Old 11-13-2012, 08:18 AM   #10
Sounds like they're a pretty damn good by. Especially for lowered mustangs. What kinda tips did you have on your car man? They look sick.
Old 11-13-2012, 08:28 AM   #11
It's not me, it's you.
primer2tone's Avatar
+1 I went 6k after I lowered my car and wore the inside of my front tires bald. I only had 12k miles on the car. I've got M&M c/c plates now. I've put about 15k on these and my tires are still looking good.
Old 11-13-2012, 09:45 AM   #12
cliffyk's Avatar
CC plates are needed when you lower our cars by much more than 1-1/4", this is because the stock CC plates do not have sufficient adjustment range to get the camber set properly.
When you lower the car via shorter springs the negative camber increases, and will cause the inside of the front tires to wear excessively--depending on how much the negative camber has been increased. Camber of -1.2° or more will cause uneven tire wear, however it also improves handling; some autocrossers run -3° or more.
Aftermarket CC plates extended the adjustment range and let the camber be set at the factory spec (-0.50° ±0.75°). For best handling and acceptable tire wear camber of -1.2° to -1.4° is what I recommend; if improved handling is not a concern stick with the "negative" side of factory spec, -0.7° to -1.0°.
Caster should be set at +4.0° or better (I run 5.5°) the factory spec is 3.2° ±0.75°.
Old 11-13-2012, 10:09 AM   #13
I have noticed that the tops of my wheels kinda lean inward and with CC plates that will straighten them back up and keeping the inside part of my tires from wearing? Mine is lowered about 1.7".
Old 11-13-2012, 10:14 AM   #14
Poopyhead44's Avatar
My guy says he was able to get better than factory specs with my cc plates
Poopyhead44 is offline   Reply With Quote
Old 11-13-2012, 10:19 AM   #15
Yeah I went to the alignment shop yesterday and there was another mustang in there that was lowered and had the CC plates and he said with these put in this car is perfectly aligned and he said its a must have for lowered cars. Is it easy install though cause he was $500 for install, and realignment.
Old 11-13-2012, 10:22 AM   #16
They are super easy to install I did mine myself then 80 bucks for alignment
Old 11-13-2012, 10:27 AM   #17
Don't you just have to drill two holes?
Old 11-13-2012, 10:34 AM   #18
I did drill a couple holes but its been a couple years I just remember it only taking about an hour. I bought them from am and they came with instructions.they will give you alot of range to get your alignment dead on
Old 11-13-2012, 11:13 AM   #19
4 inch stainless steel
Old 11-14-2012, 09:36 PM   #20
Didn't have any clearance issues with the cut outs? I thought our years were a little more narrow than the 05-09s. That's why I thought they could fit 4 inch easier? Did they tilt done any?
Old 11-15-2012, 01:35 AM   #21
Nope no clearence issues at all. They maybe stuck under about 1/4 of an inch but not really noticeable
Old 11-15-2012, 07:36 AM   #22
Yeah sweet they looked good man
Old 11-15-2012, 11:30 AM   #23
Thnks
09:48 PM
