Top end pull - Mustang Evolution
Old 11-13-2012, 04:55 PM   #1
Jheard517's Avatar
Top end pull
I'm hearing that with 4.10s at the end of 4th gear is like 110mph. When you shift to 5th do you still pull hard or is it slow motion? I have a stock 00 gt.
Jheard517 is offline   Reply With Quote
Old 11-13-2012, 06:33 PM   #2
ksrumbel's Avatar
My 4th gear tops out at about 105 with 4.10s. It feels like it still pulls to me in 5th gear. I don't do it very often or feel the need to do so. Are you thinking about doing a gear swap?
ksrumbel is offline   Reply With Quote
Old 11-13-2012, 06:35 PM   #3
AgentOrange's Avatar
5th is your overdrive as where 4th is your direct drive.. don't expect it to pull as hard as 4th will. Good news there is you won't trap 110 in the 1/4 so no need to pull in 5th.
AgentOrange is offline   Reply With Quote
Old 11-13-2012, 06:57 PM   #4
ksrumbel's Avatar
^this. I am topping out 4th in the 1/4. I won't need 5th in the 1/4 unless I add a bit more hp.
Old 11-13-2012, 07:07 PM   #5
I'd have to add another hundred hp to need 5th in a 1/4 lol!
Old 11-13-2012, 07:28 PM   #6
ksrumbel's Avatar
Yeah I won't need it unless I slap on a supercharger. And If I were to do that, I would consider another gear swap. Maybe 3.90s or 3.73s.
Old 11-13-2012, 07:29 PM   #7
Venomouz831's Avatar
4.10's in an auto is the best thing I did. In the 1/4 was over 102mph
)02 Gt, Founder of WE2G
Old 11-13-2012, 08:41 PM   #8
Jheard517's Avatar
I'm talking about untrack related stuff. Like starting at about 70mph. If you know what I mean.
Old 11-13-2012, 08:55 PM   #9
The mods here won't go for this very long and for good reason, but if you want some advice; your car is better suited to running from a dig, at a prepped track. Without a turbo or a blower our cars just don't pull hard enough on the top end. Can't help but mention how pointlessly dangerous and costly such ventures are.
Old 11-13-2012, 08:58 PM   #10
Lorraine's driver
ab_mach1's Avatar
Not really sure what you mean? The track is really the only place to safely exceed the speed limit anyway. Did you know Mustang Evolution has rules against street racing discussions on the forums?
Instagram: @ab_mach1
Old 11-13-2012, 09:20 PM   #11
Jheard517's Avatar
Never said anything about street racing
Old 11-13-2012, 09:38 PM   #12
You said untrack. That fully implies street
Old 11-13-2012, 11:36 PM   #13
JetLife 01GT's Avatar
He's talking about driving on the autobahn... lmao
2001 GT
Engine/Drivetrain: SCT iTSX with BAMA 91 Race Tune, Airaid CAI, JBA O/R H-Pipe, SLP Power-Flo Catback, Exedy Stage 2 Clutch, Exedy Lightweight Flywheel
Suspension: H&R SuperSport Springs, KYB Shocks & Struts
JetLife 01GT is offline   Reply With Quote
Old 11-14-2012, 03:45 AM   #14
WheelStander's Avatar
Or in Texas. Don't they have a no limit area?
Induction: Kenne Bell | wHp: 515 Tq: 503 | 1/4 Mile:11.09@123
WheelStander is offline   Reply With Quote
Old 11-14-2012, 06:22 AM   #15
Slvr01GT's Avatar
I believe they have a toll road that has a speed limit of 85.
Slvr01GT is offline   Reply With Quote
Old 11-14-2012, 06:31 AM   #16
Ok. I know there is a highway somewhere in the states with unlimited.
Ah, ND use to have no upper speed limit areas but they had to come to compliance to get federal highway funding.
Old 11-14-2012, 07:12 AM   #17
Your car doesn't have enough power to pull through 5th quickly at all. Gears are not gonna help you.
Old 11-14-2012, 08:33 AM   #18
cliffyk's Avatar
Here are a couple of online calculators that will help sort a lot of this out:
How Fast Can I Go in Each Gear?
How Much Horsepower Does it Take to Go How Fast?
For those with serious engines here's a "How Fast..." calculator carried out to 9000 engine rpm...
Old 11-14-2012, 09:33 AM   #19
Lorraine's driver
ab_mach1's Avatar
I can never get your links to work from the iPhone app.
Old 11-14-2012, 09:34 AM   #20
Lorraine's driver
ab_mach1's Avatar
I get this...
Old 11-14-2012, 10:53 AM   #21
cliffyk's Avatar
They are fixed--I had my dev server (behind a firewall) up when I created the links and they got pointed to that.
Here are the good links, repeated here for clarity:
Old 11-14-2012, 11:02 AM   #22
Lorraine's driver
ab_mach1's Avatar
That fixed it. Thanks cliffyk
02:46 AM
