Crower 268/272 - Mustang Evolution
Old 11-14-2012, 11:54 AM   #1
truckinu's Avatar
Crower 268/272
I found a man selling these cams. Would I need to re-spring my heads for these? Stock PI's now.
truckinu is offline   Reply With Quote
Old 11-14-2012, 11:57 AM   #2
infamous281's Avatar
Springs/retainers you will need with any aftermarket cams besides Anderson cams
Old 11-14-2012, 05:31 PM   #3
1996mustang's Avatar
Not necessarily true depends on the mildness of the cam some work on stock springs. I would look up the part numbee and see if they would work without respringing....however slow is right its best recommend to upgrade springs to prevent premature failure of the springs.
Old 11-14-2012, 05:47 PM   #4
truckinu's Avatar
Ok. The cams are 268 intake and 272 exhaust. Doubt they have the cam card.
Would this make them stage 2's?
Says they have approx. 2000 miles on them and asking 350 with the cam gears still attached.
Old 11-14-2012, 05:59 PM   #5
I say go on the crower website and check out their specs
Old 11-15-2012, 07:01 AM   #6
truckinu's Avatar
Wouldn't know what I was looking for. Just numbers to this lame brain.
Old 11-15-2012, 07:19 AM   #7
Ill see if i can find the link then ill post ot here
Old 11-15-2012, 07:39 AM   #8
http://www.crower.com/camshafts/ford...pair-4721.html
02:19 AM
