Shaker hood/ non functioning hood scoop - Mustang Evolution
Old 11-16-2012, 02:46 PM   #1
ToHellAndBack's Avatar
Alright guys I have 2 questions to ask. First, is it possible to make the non functioning scoop on the 99-04 work. And second if so has anyone heard of having the shaker under the hood scoop so it's not visible till u pop the hood?? Any pics. (Tell me if I'm just crazy)
"I'm not tailgating... I'm drafting"
ToHellAndBack is offline   Reply With Quote
Old 11-16-2012, 02:51 PM   #2
Venomouz831's Avatar
On my v6 it was functional, I cut out the piece and ha air going through but idk if it made a diff or not. As for having the shaker under the scoop idk if their would be enough room and the cost to get it and fab it won't be worht it
)02 Gt, Founder of WE2G
Old 11-16-2012, 03:04 PM   #3
I think I'll be buying the shaker from AM regardless. I was just wondering if I could leave it under my hood scoop or if I had to do it like everyone else
Old 11-16-2012, 03:10 PM   #4
Usually people buy the hood with the cutout or fab one of their own. For that money you can buy something more performance enhancing
Old 11-16-2012, 03:17 PM   #5
Mine is functional, the little honey comb piece I drilled each circle out and cut the piece under the hood to air would flow in. Works fine never had any issues, it makes the motor run a little cool which is good and even at high speeds it holds on good.
Ryan7racin is offline   Reply With Quote
Old 11-16-2012, 03:26 PM   #6
Here's some pics I just took....
ID:	76245   Click image for larger version
Old 11-16-2012, 04:02 PM   #7
Matticus's Avatar
Would you not be better off just taking the honeycomb part out? Or can you even do that?
Matticus is offline   Reply With Quote
Old 11-16-2012, 04:14 PM   #8
It's not me, it's you.
primer2tone's Avatar
Like that, the drilled out honey comb acts as a screen and helps keep debris and some water from getting in.
Old 11-16-2012, 05:22 PM   #9
+1 what he said, with just a wide open hole all sorts of trash would get in there also alot of water when it rains. Believe it or not when it rains I get zero water under the hood.
Old 11-16-2012, 05:24 PM   #10
I really like that idea! How hard was cutting the hood? And how big is the hole
Old 11-16-2012, 06:02 PM   #11
The hole is the width of the hood scoop, just cut the little piece that has the pony stamped in it
Then under that is like a plastic piece that separates from the metal hood. Here's a little "how to guide" it's pretty simple. Like I said I get no water or trash in the motor bay. I have also head of putting a piece of wire mesh where it's open going into the motor. At high speeds I have no issues what so ever.
ID:	76269   Click image for larger version
Old 11-16-2012, 06:03 PM   #12
http://motortalkblog.com/2010/12/05/...op-functional/
Old 11-17-2012, 02:10 PM   #13
Matticus's Avatar
Is the under hood insulation entirely necessary to have on?
Old 11-17-2012, 02:23 PM   #14
No,I just left mine on cause I think it looks better. You can take it off.
10:11 AM
