Window problem - Mustang Evolution
Old 11-17-2012, 04:06 PM   #1
chris25's Avatar
Window problem
My window gose down a little bit it does not go down all the way it seems like it's getting stuck has anybody had this problem
chris25 is offline   Reply With Quote
Old 11-18-2012, 01:42 AM   #2
Black99Snake's Avatar
does it go down very weak like? or just goes and stops all of a sudden? if it just stops then it may be hanging up on something. mine was hanging up once at about halfway down and one day it just fell completely down took the door panel off and the arms that cross in the middle had some how got bent and broke. but if its just goin down slowly it may just be the motor goin out. i would check inside the door frame for anything and if you dont see anything id check out a salvage yard for a use motor and see if that helps
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 11-18-2012, 11:09 AM   #3
Rockpanama's Avatar
I have 2 03 mustangs that every once in a while I have to tap on the window motor to get it to work.
Rockpanama is offline   Reply With Quote
Old 11-18-2012, 11:19 AM   #4
chris25's Avatar
It don't go down snow it just gets stuck a Little bit half way I took off my door panel and it looks like 1 of the slides are bent
03:13 PM
