functional hood scoop? - Mustang Evolution
Old 11-17-2012, 06:41 PM   #1
fomoco4life's Avatar
Wondering if anybody has made their non-functional scoop actually functional? Was thinking of fabbing out some sort of duct once I finally get my CAI. I'm sure someone must have already done this but I thought I'd ask ya'll before I start trolling the Internet.
Old 11-17-2012, 09:34 PM   #2
Look down a couple post this was just posted.
Ryan7racin is offline   Reply With Quote
Old 11-17-2012, 10:18 PM   #3
1slosix's Avatar
i've seen a couple of people do this...usually they regret it due to making their engine bay dirty all the time..and having water fall directly down on top of where the coils are since there's not trap for a functional scoop.
carving corners like a boss
Old 11-17-2012, 10:34 PM   #4
Eturner's Avatar
This is all but totally point less!.. You won't be able to create a "Ram Air" affect, so about the only thing you'll do is just make a really fancy Fender Mount CAI!.. My advice is don't do it!.. It is a waste of time!..
Old 11-18-2012, 05:21 AM   #5
DaBluedude's Avatar
Buy a professional shaker system. That's as good as it gets.
2003 Mach 1
Old 11-18-2012, 07:39 AM   #6
Eturner's Avatar
+11 on functionality and looks!..
Old 11-18-2012, 03:03 PM   #7
Well I like the Look and functionality of a shaker, but I prefer the looks of our scoop. I was looking to pipe some sort of duct to my CAI to make it an actual RAM system. I'll keep researching... the more air the better
Old 11-18-2012, 06:39 PM   #8
Eturner's Avatar
One problem!.. It doesn't actually Ram anything!.. The best it does is just help to funnel out side air to the filter!.. I've researched it myself, and basically by the time the air reaches the filter it has slowed down to much for it to be effective!.. In the end you'll end up with wasting time and money with next to no gains to show for it!..
For a "Ram Air System" to be effective you'll have to completely seal off the scoop to the hood!.. Our scoops are just for show so they are simply bolted down!.. Next you have to route the air to the filter and make sure that is also sealed off!.. Then you have to seal off the filter housing to everything else minus your "Ram Air" setup!.. One little leak in the entire system and you loose that Ram Air effect!.. But like I said above, by the time the air gets to the filter it has slowed down so that you no longer have that Ram Air effect!.. Just think of where your Hood Scoop is in relation to where your air filter is, and then the distance the air would have to travel from the scoop to the filter!.. It's just to far!.. For it to even be some what effective, your scoop would have to sit right above or right in front of your air filter!.. Not to mention the speeds that you'll have to travel at for it to take effect!..
Like I've said I already researched it and I'm just trying to save you from wasting your time and money!.. Save your cash and time for a mod that will actually affect your performance in a positive way!..
Old 11-18-2012, 07:03 PM   #9
Mine is fully functional, it makes my motor run a slight cooler than before. I get no dust or water in mine, ill post a link of what I did. http://motortalkblog.com/2010/12/05/...op-functional/.
It's very easy to do and I always thought it was dumb to have a hood scoop that didn't work. I have ran very high speeds with mine like this and never a problem I would do it again if I had to all and all I'm happy with it.
Old 11-18-2012, 07:06 PM   #10
Here's some pics.....
ID:	76629   Click image for larger version
Old 11-18-2012, 07:15 PM   #11
Eturner's Avatar
Did the same thing with mine!.. Even took it a step further and removed that underwood blanket!..
Old 11-18-2012, 07:19 PM   #12
And you don't like it? I haven't had any problems with mine at all, and when it rains I get zero water in mine. Im sure it doesn't give it anymore power or anything like a ram air but I did make it run a little cooler. Before my temp gage was dead even up and down now it runs a little on the cold side.
Old 11-18-2012, 07:56 PM   #13
Eturner's Avatar
Didn't say I didn't like it!.. Simply that it don't give it a "Ram Air" affect like the OP is looking for!..
Old 11-18-2012, 08:02 PM   #14
Yup you are correct.
Old 11-19-2012, 12:32 AM   #15
Cool thnx guys...cooling air, no RAM, still bettr than 0 functionality
Old 11-19-2012, 01:05 AM   #16
1slosix's Avatar
the temp gauge in our car is kinda useless though..it's one of the first gauges i put in my last two stangs (autometer temp gauge).
i would however like to see some under hood temps taken Ryan if you have a friend with a new edge GT. Yes it won't be exact but with some similar running conditions before the testing you can get a couple temps and then do an average.
04:50 AM
