rebuild time 163xxx - Mustang Evolution
Old 11-18-2012, 11:26 PM   #1
trejo_03's Avatar
rebuild time 163xxx
Transmission and motor want to stay under 3000 fresh rebuilt heads at 1628xx but idk about boring the motor or kepping at factory demensions
---------- Post added at 12:25 AM ---------- Previous post was at 12:25 AM ----------
Any suggestions
---------- Post added at 12:26 AM ---------- Previous post was at 12:25 AM ----------
03 gt 4.6 with t3650
trejo_03 is offline   Reply With Quote
Old 11-19-2012, 02:23 AM   #2
2003mustangGT's Avatar
Under 3000 is gunna be hard? Are you trying to go forged internal? What is the plan for your car?
2003mustangGT is offline   Reply With Quote
Old 11-19-2012, 06:58 AM   #3
trejo_03's Avatar
Yupp supercharger after college
Old 11-19-2012, 10:31 AM   #4
infamous281's Avatar
20 over and get forged rods and positions if your going NA
---------- Post added at 11:31 AM ---------- Previous post was at 11:31 AM ----------
Pistions
Old 11-19-2012, 12:35 PM   #5
Pistions
Either way N/A or not you need forged internals. Why not jjst stroke it to lets say a 5.0? Talk about nasty! And depending on the supercharger quite a few other things. Not to mention suspeions to handle the power. Without that the power is nothing. You an throw how 700 all day but of you don't have the right suspension set up its doesnt do you a bit of good.
Old 11-21-2012, 01:24 PM   #6
v8pony's Avatar
163XXX and both tran and engine are done?
2002 5spd GT
Feb 2013 Mustang of the Month
Old 11-21-2012, 02:03 PM   #7
AgentOrange's Avatar
You aren't keeping it under 3000 unless you can do all the machine work yourself. Best bet is to save and go big after college.
AgentOrange is offline   Reply With Quote
Old 11-21-2012, 03:46 PM   #8
M97stang's Avatar
Mine motor was rebuilt at 160,000 bore over 30 thru in a tremic tko 500 then several mods in clustering full p.i swap intake sct tune bassini xpipe c.a.i alumnium drive shaft 3.73 gears made 320 ft torque and 310 hp at the crank no problems no issue's
M97stang is offline   Reply With Quote
Old 11-29-2012, 01:22 AM   #9
trejo_03's Avatar
No just tranny is all ****ed up but the motor burns oil every so often hasn't since I parked it cuz of tranny but it would only smoke after running at normal temp for a good 10 15 minutss but I rebuilt the heads because gaskets went out so I think oil might of got in the cats or something going to get em gutted (small city lubbock, Texas = no emissions test just make shure they are under the car) after I fix tranny to see what that will do
Old 11-29-2012, 01:26 AM   #10
trejo_03's Avatar
Could be o rings to but I want to do tranny first before engine I already had some fun with the head job last summer
ID:	78365   Click image for larger version
10:07 AM
